Connect with FTP - what to save?
  • Teemo
    • Dec 2012
    I'm planning on changing images on my Dreambox 500s+ - but first I thought I would backup essential files. I am currently running a Gemini image with ccam and am planning to change to Commando or Pli. What files should I save before flashing with a null modem cable? Thanks for all your discussions as well. It's a lot of help when your trying to make sense of it all PS: Backup with Dreamup doesn't work so thats not an option. And transfering ALL the files via FTP gives me some "Failed transfer" messages. (Probably in use by the DB)
  • 00360362878
    • Mar 2010
    • 488
    Teemo the only file that you need to save is your cccam.cfg file if you use a server and you will find that in var/etc.
    A different image will require compatible plugins/extensions.
    • sohail anwer
      • Mar 2009
      use flash wizard for making backup..all file and services automatically save in backup...
      • letnimy
        • Feb 2011
        • 33
        it is better to re-install than to make backup
