Commando 14.7 DM500 Release
If you're on 28.2E, have you considered a) reading the helpfiles, and b) running AutoBouquets, rather than a standalone Scan?
AutoBouquets magically tweaks "Primetime" service from service_type="04" (data) to service_type="01" (TV)
If only more peeps could be arsed to read the helpfiles, which took dozens if not hundreds of painstaking man/hours to compile, just to point you guys in the right directions...
Cheers- AL
Hi paphosal
I noticed that you seem to be the man that knows the commando imgae.
I am trying to figure out why i am having lip sync problems with ver 14.7 running mgcamd
Iv noticed that you said that it was all to do with the cam on one of your pages, I have tried all the updates with this verson but with no joy.
I have had to revert back to verson 14.6 to see if the problem still happens with mgcamd as i had it working with 14.6 on cccam with no problems But if as you saying its the cam why would it happen with the freeviews
ThanksComment
Im still having these issues on 14.7.. using CCam.. i gave up long ago and just live with it..!Hi paphosal
ThanksComment
In the first C14.7 online update (04 Mar 23) we implemented a patched version of LraiZer's old dBox2 Audio Priority diff. This gave English Audio (no narration) right across the board- good news for everyone!
It also cured TS Recording issues that had been reported by mickb82 on here, who wrote an excellent tute on the subject which is included in the helpfiles library. Under heavy testing, it soon became apparent that this new setup worked best with FastZap = ON (the opposite of the case beforehand), which gave a double bonus of faster channel zapping.
But as always, life is a compomise and something else gets adveresly affected. Yes, lip-sync does tend to drift slightly after a period of time. Seems worse on some channels than others. But in a 2 hour TS film recording, peeps report that lip-sync remains perfect throught the entire duration of playback.
The cure for lip-sync when this does become an annoyance with normal viewing is to simply do a quick channel up / channel down, and this brings audio back into perfect sync with video. Don't bother trying FastZap = OFF as this makes lip-sync much worse, even when you zap to another channel.
This has nothing at all to do with softcams btw.
Cheers- AL
After messing about with all the other images for the 500s, i decided to give this a go, not sure how it runs on multi sat but perfect on 28.2. Awesome image, wish i'd tried it first other than the other load.
Thanks for the upload and its a cracking imagesigpic
"Make it idiot proof and someone will make a better idiot."Comment
.......... anyone else experiencing this problem?
