Commando 14.7 DM500 Release
  • PaphosAL
    Old Git
    • 1064
    #451
    At the time of posting, there have been 273 downloads of our C14.7 23/10/2013 update image, so the attachment is kosher. I just tried downloading it back to source, but it doesn't seem to want to know....
    Devilfish? Cheers- AL
    • flyingpig
      • Aug 2009
      • 930
      #452
      Hello All,
      Having a bit of a mare with the DM500 in the front room -- and hope you can all help in some way.
      I tried to get BT sports yesterday and it said chanel not found so I ran autoboquet from the menu. It completed and at the end said there was something wrong with chanel "Playboy" but not a problem if we are connected to the internet - which the box it.
      After that, it said it didnt resolve the problem. and was cancelling scan --- sorry my terminology is not as it was on the screen, but the meaning of the messages are right.
      Now I have no channels and when I go to service and run a scan I get a message saying cant find any transponders? I reboot the machine, run a scan and it finds a few channels, I then run autoboquets again but then there are no channels again?
      Is there a way to resolve this without a reflash? Can I send info to the box such as a channel list which will sort it?
      • gezim
        • Nov 2013
        #453
        hi there
        sorry i am new here i just installed this image and i have problem now connecting with dreamset or dcc to put buqets i don't really know what to do i can login to web http without a problem but at dcc and dreamset i cannot so what can i do thanks
        • NICETOBNICE
          • Nov 2011
          • 551
          #454
          Hi guys i have four dm500s running commando 14.7 newest online update but for some reason on 1 of the box's i cant seem to get epg stream to work .
          The channels are all great on every box as its on a quad lnb
          any suggestions
          • PaphosAL
            Old Git
            • 1064
            #455
            swap around time, to find out if it's a) dodgy port on LNB, or b) dodgy PSU on one of your boxes, or c) dodgy tuner on one of your boxes?
            Having two or more boxes makes problem-solving a LOT easier, LOL!
            Cheers- AL
            • NICETOBNICE
              • Nov 2011
              • 551
              #456
              Cheers- AL
              Thanks Al
              I have just checked and now no its the box' But the big question is why? think we need to roll this back a little now.
              all my box's were working fine until the weekend when i decided to add a new box and cable to my static disc' i fitted a new quad lnb and fine tuned the dish' the signal was much better after i tweaked it .
              The question is ? maybe the signal is now to strong i noticed on the dodgy box it struggles to get certain channels like boxnation' which i know has to be a good signal strength.
              Thing is it was fine before i changed the lnb
              I have tried every feed in the house with the same results
              confused
              • psats
                • 823
                #457
                Originally posted by NICETOBNICE
                Thanks Al
                confused
                as you have tried useing other feeds / power packs personly i would reinstall
                from scratch the firmware on the iffy box.
                • NICETOBNICE
                  • Nov 2011
                  • 551
                  #458
                  thanks psats i already done that' infact i made a backup on the working dm500s and ftp'ed it into the dodgy box.
                  then installed the backup image.
                  not sure if a good flash with the null modem lead is better what you think ?
                  • NICETOBNICE
                    • Nov 2011
                    • 551
                    #459
                    Guys all sorted now
                    I added a attenuator and now its perfect never seen this before.
                    • the man
                      • 1660
                      #460
                      hi guys iv had a 500s on pli for years im trying this and its amazing but i cant see $ch as no os*cam ect , iv read its in the menu but im lost , does this image have and download plugin section? for skins rxtras ect? if so pleases advice , thank you
                      • NICETOBNICE
                        • Nov 2011
                        • 551
                        #461
                        have read of the notes in the tuxbox editor
                        add to var/bin/emu
                        watch what your saying chief as we dont discuss these things here
                        • pjmorie
                          • Mar 2012
                          • 45
                          #462
                          There is no plugin download section with the image so you will have to download and install the files you need manually, not a big issue. Have a look at the 'Hints and Tips.txt' file which is located in /var/etc/info, this should help you out.
                          You can uses the built in TuxBox Commander to view file or use an FTP program to open it on your computer.
                          • the man
                            • 1660
                            #463
                            thanks pal , i cant get the new os##m working on any image , in the past there was away a helpfull sole uploading images with os/cc 2.1.3 on 500s
                            best image was darkstar2 with os and cc 2,,1,3 if any one has a working image with the latest bits and bobs , pls pm me
                            good bless
                            • eamondo
                              • Oct 2010
                              • 16
                              #464
                              Can someone please help me I am going mad I cant get a new satlittes xml onto 14.7 it makes screen go black but i do notice the details of the xml file are displayed in different order than the xml file in the box
                              any ideas anyone please
                              • pjmorie
                                • Mar 2012
                                • 45
                                #465
                                good bless
                                If you do manage to get it working with o###m can you PM me.
