Commando 14.7 DM500 Release
  • zee24
    • 3342
    #481
    Originally posted by cookie12
    turn off fast zapping
    how do I do this???
    • cookie12
      • Feb 2013
      • 17
      #482
      menu settings boot and standby options
      • the man
        • 1660
        #483
        made it way worse mate . thanks tho
        • Kalipo
          • 1687
          #484
          Originally posted by zee24
          Press -menu- services- bouquet editor- entertainment- press green on remote to add channels- scroll thru list and find all itv +1 channels
          I added them all then went back to see which were which region as they they dnt say until i watched each one then i went back did the first 5 steps above again and deleted the channel regions i dnt want
          Hi, thanks for that.. this doesnt sort the issue as i use autobouquets everyday at 5am.. it reverts it back.. i know this as one night i felt the urge to use the adult channels.. i got annoyed having to flick through all the crap channels.. so i deleted them.. next day they came back.. ha..
          • cookie12
            • Feb 2013
            • 17
            #485
            did u reboot ur box wen u turned it off ?
            • the man
              • 1660
              #486
              yes made it worse , reflashed same same, if i turn it off it goes out or lip straght away , if on it takes a hour or so to lose sync , does it work 100% for you? i love this image but need to fixed
              thanks pL
              • cookie12
                • Feb 2013
                • 17
                #487
                thanks pL
                yes m8 works perfect for me
                • spudorange
                  • 242
                  #488
                  or you could press the tv button
                  or you could go up a channel and back
                  reboot not needed
                  happens to me now n then i just turn off box and on again sorts it out.
                  • Kalipo
                    • 1687
                    #489
                    Now when mine goes out of sync I press the audio button and it's sorts it for another 2-3 hours...
                    • spudorange
                      • 242
                      #490
                      If you read the help bits on your box (tuxbox commander) I think)
                      you will see it say's TV button
                      that works every-time for me
                      • Kalipo
                        • 1687
                        #491
                        Audio resets the synch on my box...
                        • spudorange
                          • 242
                          #492
                          post 364 from paphosal "http://www.digital-kaos.co.uk/forums/f214/commando-14-7-dm500-release-316617/index25.html"
                          If you're on the latest 19 Sep update of C14.7 then you couldn't have read the wotznew announcement readme.
                          Just press the [TV] button to clear lip-sync issues after watching the same drivel for 2 hours!
                          Cheers- AL
                          • Kalipo
                            • 1687
                            #493
                            Cheers- AL
                            No I didn't read it! Why? When the audio button does exactly the same thing.. and I'm on the latest update..
                            Valami ilyeshmi erred??
                            • spudorange
                              • 242
                              #494
                              Not my words (regarding reading it) I just cut and pasted the post from him mentioned in the thread.
                              Not sure why the switch, but he is the man who knows so must be a reason it's been switched
                              Cheers- AL
                              • Kalipo
                                • 1687
                                #495
                                Tbh I've not used the dm now for 2 weeks as we have a smart tv with Netflix/lovefilm and plex.. the dm in our house is coming to an end .. I'm afraid if I put it in the loft again it will die..
