Help with satellites.xml please (lost sly sp 1 on commando but got it on pli)
  • spudorange
    • 242
    Hi
    Sly Sports 1 keeps going off at halftime with the current 14.7 autobouquets. "12110h 4211 2021 515 643"
    To try and resolve I popped pli on and noted that the settings of one that works ok (4th in list of all) is "12148H 4611 2023 516 644"
    Auto Bouquets on 14.7 currently pick it up as that channel up as "12110h 4211 2021 515 643" which goes off during live matches. (second half mainly)
    previously I have managed to transfer to desktop and work on such files as satellites.xml using notepad++
    Right now I can only open up in notepad which is just a mess, or not at all, transfer etc is greyed out.
    Anyone able to post up a copy of the file with those changed settings or advise how I can edit satellites.xml myself please.
    and happy new year to all
  • mtv1
    The Stig PT
    • 4413
    http://www.digital-kaos.co.uk/forums...elease-316617/ look at the update version if still same contact your supplier tell him/her to update there server
    http://www.digital-kaos.co.uk/forums...23-10-2013.rar that one
    • mtv1
      The Stig PT
      • 4413
      satellites.xml generator / transponder .ini generator make your own here
      • spudorange
        • 242
        thanks for both posts mtv1
        • spudorange
          • 242
          Originally posted by mtv1
          Tried this yesterday and it made one for 28.2, BUT how do I know it's got the correct sly sp 1 ("12148H 4611 2023 516 644")
          and not the usual "12110h 4211 2021 515 643" which goes off during live matches. (second half mainly)
          Remember all 4 work until a live match then the "12110h 4211 2021 515 643" (the usual 14/7 autobouquet one) scrambles at half time
          I need to put this in but do not know how to ("12148H 4611 2023 516 644")
          any ideas please
          My supplier said use (O***M) or change the pid (which I am trying to do) and I don't think I can change to O***M on a dm500
          appreciate further input
          ps I updated online, then did another autobouquet but still scrambled at the time. (ok now til next live game i suppose)
          • psats
            • 823
            why not add the other ss1 into sports that way you can switch
            • pjmorie
              • Mar 2012
              • 45
              any ideas please
              1. If your Commando 14.7 image is up to date then you can download a satelites.xml from the online utilities menu.
              2. As PSATS mentioned you can add the other SS1 feeds, to do this on Command enable the A-Z Bouquet. If your using the Irish feed of SS1 then the issue seems to be worse.
              3. Oscam can be installed on a DM500s.
              • spudorange
                • 242
                That would be useful can you advise how that is done please
                I can see the bit from PJ about "enable the a to z bouquet" but not noticed this, where is it please
                sorry to act dumb
                thanks to you both for replies
                • psats
                  • 823
                  sorry to act dumb
                  menu / services / bouqet editor / highlight sport press ok / press green / find the ssp channels you want to add with ok once done exit and save
                  • pjmorie
                    • Mar 2012
                    • 45
                    sorry to act dumb
                    Provided you are on the latest release with all the updates then to enable this A-Z bouquet press
                    BLUE -> BLUE -> GREEN -> RED -> YELLOW.
                    After running AutoBouquets you should now have a bouquet called Astra 28.2E which is an A-Z listing of all the channels.
                    • spudorange
                      • 242
                      Thanks to both PJmorie & psats
                      much appreciated.
                      suppose I need to take time to read those helpful how to lists that are in there doh!!
