Can this image work with other region like Russia. I installed it and only can scan astra for UK. I need to set-up for Eutelsat W4/W7. I love the look and feel of this image. Please advice
Commando v14 for the Dreambox 500s
In the scan settings, you should be able to scan other satellites, I can do it fine here with a motor dish.
SSComment
if you have a static dish then try these settings in scan menu
bouquet = satellite-bouquet
diseqc = no diseqc
satellite = eutelsat sesat 36.0e
fast scan = offAttached FilesComment
Can I load mgcamd setting from my old dm500s that is working on enigma 1, if so where can i load those settings ?
I also have a backup of my services, satelite.xml can i put them in ? (where) Thanks for all your help.
My gold is to change this dm 500s to the new enigma2. I hope this can be done. You rock for helping....Comment
I see no this in the list of sats to scan
Eutelsat W4/W7.
How can I add my list of sats, where can i put the satelite.xml file so it will see my Russian sat?Comment
Yes, C14.4 Blue button Softcam Menu fully supports mgcamdCan I load mgcamd setting from my old dm500s that is working on enigma 1, if so where can i load those settings ?
services.xml and bouquets.xml must be in Neutrino format (not enigma E1) and go into /var/tuxbox/config/zapit
Your satellites.xml goes into /var/etc
It's worth backing up existing files from the release image before you go overwriting anything.
Cheers- AL
russian Cyrillic fonts Not showing right.
Thanks for all your answer got it all to work, but found out the roms fonts does not support russian Cyrillic fonts
. is there a way to do this ?
It's a long shot, but try this: In /var/share create a new subfolder named fonts
Then un-rar the attached font file and FTP it to that new folder. So you will see
/var/share/fonts/md_khmurabi_10.ttf
Reboot, and then tell us if you get the cyrillic characters or not?
Cheers- AL
I will give it a try now, get back to you..It's a long shot, but try this: In /var/share create a new subfolder named fonts
Cheers- AL
I went through what you said about the fonts but in the ftp there was already this font.?????It's a long shot, but try this: In /var/share create a new subfolder named fonts
Cheers- AL
tried the font you sent didn't work, i even took the font from my old image and still no work. HMMMMMMMMMMMMMMIt's a long shot, but try this: In /var/share create a new subfolder named fonts
Cheers- AL
