Hi all
First post here i know there are similar posts but nothing to tell you how to maually get red button services, even HD sports. found this from another site so thought i would share.
open dreambox edit
open bouquet you use in Dreambox edit
now down the left hand side you have all channels available
look for channels named 1481 through to 1499 all of them
they will be data channels
select all
right click and select change to tv
now individually double click and under service data - rename (i used red button sports) and save i kept the numbers as well and copied and pasted red button sports
only after this did it change from data to tv
I then put into interative folder
click on save on top left hand side then FTP beside it
check details i.e IP addy then send files wait confirmation
then click reload settings await confirmation
once done you will have all channels for red button services for sport.
only problem there is comentary is the original game on Sly 1/2/3 so on remote click audio and you'll get
English
Arabic
Arabic
Bengales
and so on
well i went through them all until i found the commentary for game i was watching, it will be there.
These will automaticly revert back to Data channels if you use dreambox edit to amend other channels after this, so follow all the way through again until they are all there
open dreambox edit
select all
English
Arabic
Arabic
Bengales
and so on
