DM500S Gemini 4.7 CCAM2.3.0
  • bagleyg
    • Jul 2011
    I have just flashed my dreambox DM500S with Gemini 4.7 and tried to add CCCCAM2.3.0 and when I install reports installed correctly then I cannot load the addon, also a var.tar.gz file is created in /tmp I have tried several times. Can anyone plaese help
    Where do I find the correct cccam2.3.0 or is there a later?
    I even tried factory resetting no luck
  • blackpool1974
    • May 2012
    Is there a cccam.cfg in your var/etc folder.
    If not then try and extract the .gz on your pc to see if it's corrupted
    • bagleyg
      • Jul 2011
      Hi thanks, there is a cccam.cfg in var/etc folder it is editable and not corrupt. The gz file can be extracted on the PC and seems to install OK. Where can I get a good gz file to reinstall again
      • freck
        • 1076
        Dont add CCcam 2.3.0 to any receiver....be warned!!!!
        Freck
        • elturco2000
          • Aug 2012
          Why ...
          Why are you warning? What is the problemwith CCcam 2.3.0?
          Freck
          • freck
            • 1076
            Freck
            • zipitshrimpy
              • Dec 2012
              • 4
              I've found CCcam 2.3.0 an was going to take 2 files i need an flash it but ive just seen you said dont use this CCcam 2.3.0. What would you suggest i do please any idea?
              • warby7890
                • Oct 2012
                whats wrong with it
