dreamboxedit
  • jimbojimjay
    • Oct 2008
    • 149
    dreamboxedit
    Dreambox response: Login successful.
    ** Retrieving file list of "/var/tuxbox/config/enigma/" **
    Starting FTP transfer
    Transfer complete
    Transfer complete
    Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox. /var/tuxbox/config/enigma/
    Check the dream path settings on the option panel to point to the correct Dreambox directories and try again.
    Disconnecting.
    Disconnected.
    getting this when trying to send a new bouquet across anyone know where im going wrong, thanks,the box is an eagle 1000 with commando 14.7 on it.thanks again for any help
    why not just use the autobouquet feature of the image
    • jimbojimjay
      • Oct 2008
      • 149
      thanks for your reply have tried that keep getting transponder tsid 0822 is missing unable to do auto returning back to your loaded list thanks again
      • pjmorie
        • Mar 2012
        • 45
        Commando is a Neutrino image and it looks as if your trying to send an Enigma 1 channel list to it, which is not compatable. The reason for the missing TSID message you were getting is that several transponders were recently shifted about. There is an update availbale for the C14.7 image if you have it connected to the internet just press Blue Button -> Blue Button ->Yellow Button -> Green Button.
