Updating channels on DM500-S
  • elrasho
    • Jan 2013
    • 46
    I've searched the forum but can't find a thread that explains step by step how to update the channels on a DM500-S. It has no USB so I'm guessing I have to do it over the Network or get a RS232 > USB cable
    Any advice would be greatly appreciated
    Follow this Guide here: http://www.digital-kaos.co.uk/forums...-guide-167275/
    But change Enigma2 settings to Satellite Receiver
    • elrasho
      • Jan 2013
      • 46
      Thank you very much! Will try this tonight
      • elrasho
        • Jan 2013
        • 46
        Managed to download DreamBox Edit and connect to by box. However when I try and FTP the Bouqets it says the username or password is wrong. The username is set to root and the password is dreambox.
        I need to reset the root password so I downloaded Tuxbox Commander and installed using the below guide:
        Open tuxbox Commander and enter the directory / var / etc / and then get the passwd file, and press the button 4 (Edit) on the remote control.
        Firstly, enter the following: root:: 0:0 ::/:/ bin / sh
        also create the file passwd in ~
        This is done by selecting the first row with the arrow keys on your remote and press OK. Deleting is done with the VOLUME -,
        and writing as well as writing a text message on your mobile phone.
        Thus the Dreambox passworada without a new creation can be done with the help of Telnet. Poktene the Telnet log
        with a blank password and then house the command passwd
        It is also possible to enter a new password with the help of the DreamBox. This can be done in the Extra / Setings / Password.
        Enter a new password and that's it. Now Dreambox a new password by this time one should remember that nebismo had repeated the entire procedure
        My question is how do I do the very first step: open tuxbox commander and enter the directoy....
        Where do I open it from? Do I telnet onto my Dreambox or do I open it from within one of the Dreambox menus?
        • elrasho
          • Jan 2013
          • 46
          I gave up trying to reset the root password and instead flashed with a new image. I then setup using 28.2 as the satellite and it found hundreds of stations. I could then login as root using dreambox as the password put the Bouquets on using the above guide
          Thanks for all your help, this forum is awesome!
