keeps freezing and glitchy
  • wetdog
    • Apr 2011
    • 989
    can anyone help with this problem?
    picture freezes often for a second or so making it difficult to watch tv. no better than a SV7 at the moment.
    mick.
  • TheCoder
    • Jun 2011
    • 693
    You need to determine where the problem lies. It could be any of a number of things including -
    1/ If your using cardshare, then either the server or your internet has problems.
    2/ You have a poor signal, possibly affected by the weather or some other obstruction (clouds, tree's etc).
    3/ The image your using isn't properly configured or isn't suitable
    4/ The tuner in the box is 'weak'
    One of the first things to do is determine if the problem is present on fta channels. If it is then that would indicate your problem is more to do with tuner signal level. If the problem is only on encrypted channels then its more likely to be your server or internet connection.
    • wetdog
      • Apr 2011
      • 989
      cheers dude, its the internet connection.
      mick.
      • ramjet
        • 2995
        chances are its high ecm times from a cr*p server feed
        anything over 400ms on 28e and it will freeze
        fta channels will be fine
