nemesis 2.6 help please
  • moleman
    • Feb 2013
    Hi new here got a new dm 500 hd and want the nemesis 2.6 10r0 to ru n on it (i have dm800hd and works great for me)
    For some reason tspanel isnt on the image i got from nemesis.tv
    so i need to install manually or maybe someone can point me in the direction of an image of 2.6 that it is on
    I know this box is NOT a clone because i updated from 10r75 and no brick please help
    i am new to dboxes my dm 800 hd clone worked fine
    i know about ftp but maybe i am doing something wrong here
    pm me or post below thanks
    matt
  • mdt
    • 3034
    put this in /tmp then install via ipk installer... its a old version so will need updating through tspanel via the yellow button,regards mdt
    • moleman
      • Feb 2013
      ok tried a few images from here and thought i had bricked my box
      i could not reflash holding the power button in method with browser after flashing a gp2 5.1.
      luckily found an old usb cable which is mini usb 1 end and found the driver to trick dreamup into thinking com port 3 phewwwwww reflashed nemesis 2.6 110r75 took a long time
      then i dcc your tspanel 4.0 to tmp and installed thanks!!!!!!!!!
      updated nemesis 2.6 to 110r10
      updated tspanel 6.8
      added cccam 2.3+ config
      to me
      to do list
      drill a whole in bedroom connect coax from sat to box
      get another c line
      unless i can use 2 box on 1 line???????hint hint help me
      thanks again mdt
      and 1 more thing usb 16gb usb stick or a sata drive for timeshift-pause live tv etc...
      thanks again peeps for any help
