yes mate, the 2300 should be spot on as my older 2200 is
Post out of excitment!
PS3= krazylegz120282
if you like what people say please use the reputation or thanks button, dont just make a post to say thanks -
Right here's what I've picked out so far...
from southernsat.co.uk- Technomate TM2300 Motor
- Icecrypt 0.1db Universal Quad LNB (is this worth the extra cost compared to cheaper offerings?)
- Orbital 1mtr dish (a dish is a dish?)
- 20mtr fitting kit
- wall mount. (heavy duty I'm guessing)
Cheers!Comment
here you go..
Quad LNB.. ?20
says its 0.1db.. probably closer to 0.2db at this price.. seems fine
you might want to look at this one MTI AP8-XT2EBL 0.2dB Universal LNB from Aerial Shack MTI 0.2dB
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Maxx 110cm Dish
Technomate 2300 Motors
sigpicComment
I've ordered everything now went for the technomate TM2300 and the Icecrypt quad LNB. Once that all turns up I can put the dish up and get ready for a painful wait for the 500HD to be released
I've got another question if no-one minds. When I see a saellite listing for example say Hotbird on 13 degrees east. Where is that exactly, is it 13 degrees east from absolute south? or is it 13 degrees east from my azimuth position?...I'm getting a bit confused on that bit!
Just one other thing.. are you aware some dream boxes have issues moving certain motors??
Hopefully the 500HD wont give you any problems.
I had this problem running a quattro LNB (motor point blank would not move from the DB) However, I changed to a single low power LNB and the issue was resolved..
Just my ?3.47's worthComment
Just to add to wat OP's is saying,
i have a technomate 2300, and have been using it for almost 2 months, and can happily say it does exctly wat is sez on the box...
compared to some motors, it actually moves a lot faster...
and doesnt make a racket when moving either!
highly recommended...New Season...New hope! YNWA.Comment
thanks for the reassurance on the 2300! All that is ordered now and should be arriving this week. Already getting impatient on the whole not knowing when the 500HD is coming out (it's not even mentioned on the dream multimedia website!). I can see myself cancelling that order and buying an 800HD soon!!
Update slash asking for more help!
Hey,
***LONG POST WARNING!***
So predictably I got fed up with waiting for the 500HD to come out so ordered a 500S to play around with.
I now have the dish up, coax cable run all connected, green light on the motor happy days.
Fired up the 500S set IP address. Messed about flashing some images currently have the NabiloDM500-V08-MAXVAR image on there (not for any particular reason). Got that flashed okay and everything starts up okay.
I'm doing a transponder scan and get a good lock on Thor 1W get 93% SNR 90% AGC and 0 BER. Try to do a scan on 28.2 can't get a lock BER and AGC are okay but SNR never goes above 60%. Just done a scan this time on AtlanticBird3 5.0W no lock 61% SNR.
Went back and scanned Thor2 1.0W again SNR 93% AGC 89% BER 0. So I thought I'd scan for some channels to see what happens. This doesn't ever seem to complete, nothing changes on the progress bar. Had that going for about 15mins nothing happens so hit the exit button.
get screen saying
Done
0 new transponders
0 new TV Services
etc..
0 Transponders with 0 Services Scanned.
Press okay to close the window
Go back to TV mode hit the OK button blu button for bouquets Favourites (TV) list of 107 channels all with (removed service) next to them. If I select one I just get a blank screen.
So I have two issues can't lock any satellite except Thor2 1.0W and I can't get any channels.
My pole is plum all the way round. Motor is set to 51 degrees on the latitude scale which is my location. Dish elevation was set to 30 degrees minus 7.5 declination as per the motors instructions at this setting I couldn't lock any satellite. Currently have this set to 17 degrees which is getting me the lock on 1W. I'm assuming my dead south is correct as the motor is moving to 1W and then locking...or could that be locking to a different satellite??
I've been running up and down the ladder all day now...exhausted with different degree numbers rattling around my head...not too sure where to go from here
can anyone point me in the right direction?
Sorry for the long post just wanted to give as much detail as possible!
Thanks,
DanComment
