New with Dreambox 7020
  • GeorgeN
    • 11
    Hallo to everyone,
    As a newbie the questions are too many, but then we need to start from somewhere.
    1. I have bought a HD which I plan to install the next days. Do I need anything extra not contained in the box (example cables screws etc). Is there something I need to take special care of before and/or during installation?
    2. I have also bought a USB stick (2GB) where I am supposed to enter alternative images in order to load, but how can I do that? What else is needed in order to achieve that and how can I make my Dreambox multiboot so I can choose which image to load.
    3. I have already updated the box with the Oozoon image (with the use of DreamUp 1.3.3.4 from official site a network cable and a null modem cable (these are the only tools I have by the way)), but while searching I found that Nabilo is much better looking and hopefully with more things available. I somehow do not seem to have permission to download it. Why?
    4. After I install the HD is it possible to save and be able to view photos, mp3 and DVDs? If yes which is the relevant plugin I need to download for each of the above?
    I have many other questions but I think I will be ok for the next few days if I will have answers on all these questions.
    Regards
    GeorgeN
  • westkill
    • 2378
    hi m8
    with hdd the ide cable should be inside the box ,the only thing you might need is a few tiny screws to mount the hdd to the chasis inside the dreambox
    insert the usb stick
    then check the image in the flash oozoon in your case to see if barry allen installed by holding the blue button or via the plugin list
    if not
    is your box connected to a router via ethernet cable to make it networked
    if so
    download the barry allen plugin via plugins download button over the internet.
    barry allen multi boot plugin when installing it
    it will look for a cf card first usb second and hdd third to do the multiboot
    setup
    your devices,hdd ,usb must be installed before adding barry allen
    so you may have to reflash oozoon image after installing them
    once the plugin installed
    barry allen should of created a folder on the hdd called mb_ images
    with a ftp programe
    transfer your images to that folder in your dreambox
    then goto barry allen plgin in the oozoon image
    for some thing like extract nfi images from mb_image
    chose what image you want
    this image will be extracted to your usb stick
    so when you reboot the dreambox it will bring up a screen with barry allen and then select your image
    that image will be booted to your dreambox
    this should work as i dont have a dm7020
    for mp3,s create a folder on your pc fill it with mp3 format ftp that to the hdd on the dreambox , then use the media player on that image to play them
    • westkill
      • 2378
      ive just added this image
      Nabilosat Enigma1 DarkStar II - DM7020
      in the download section
      you may need five posts before you can download
        and give server time to update
        • GeorgeN
          • 11
          Thanks to gmb45 and especially to westkill for their answers so far.
          We had progress since yesterday...
          I managed to download the Nabilosat image and install it on the box memory. It seems better than Oozoon so far.
          Some things though do not seem to work or maybe it needs further setup...
          For example yellow button and again brings you to the menu Addons Manager -->Downloads manager and for example Skins (the same is for anything from this screen) and I get a download error...
          I just installed the HDD and it seems to be OK.
          I am just about to insert the USB stick...
          westkill could you please rephrase everything to Nabilosat terms since I now have this installed.
          Yes I have a router but the above maybe shows that there is a problem somewhere... and I do not know where.
          Lets make sure first that the image is installed correctly and there is not something missing...???
          Please refer specifically to any software needed to do the jobs described earlier (where can I find these ftp software and which are they...???)
          • westkill
            • 2378
            for the addons manager to work it needs a internet connection
            so plug ethernet into router and into dreambox
            then there should be a comunications menu
            usally in menu>setup>comunications or some thnig like that
            tick dhcp and save you should be able to download from the addons manager
            if not you might have todo a static
            ip address
            subnet
            gateway/router
            dns server
            all these should be the same as the pc , but the last digit one higher on the dreambox ip address.
            • GeorgeN
              • 11
              The box is already connected to the router.
              I manage to see the box through the web interface so the network seems to be ok. Still though the box does not manage to download anything.
              Latest news:
              I downloaded and installed an update for the router I do not know if this was it but now the box has downloaded many things.
              I have downloaded skins, plugins (jukebox, vnc viewer)
              Still can not find in the list the barry allen plugin...
              Please refer to a specific software to find/download in order to transfer mp3 to box-hdd.
              Thanks so far...!!!
              GeorgeN
              PS.
              1. On Astra 28 no frequencies were included when I installed Nabilo image why is that? of course I entered them manually...
              2. for frequency 12.411 V @ 27500 there are some channels listed in kingofsat.net as BBCi 1 to 7 all receivers (I also have a commander 6000 irci) recognize them as STREAM 1 to 6 and the other one as ITV stream. I have not managed to see these channels on my screen although the box has scaned them. I scaned them also manually (manual transponder scan) and it showed that it had scanned them. No channels added so that means that they had been scanned during the initial scan. Still though I can not see them on my screen. What is happening? do I miss something here?
              3. USB stick is plugged in but how do i know it has been recognized by the box?
              4. I have installed jukebox plugin but I do not think it works ok. I have written some mp3 on the USB stick (though my pc) and it does not seem to recognize them. I suppose I am doing something wrong here but I do not know what is it???
              • westkill
                • 2378
                try this
                Barry Allen for Dreambox 7020 and 600
                Version 4.6 by gutemine from 08.08.2008
                Release infos
                0.1.0 first official Version
                0.1.1 add LCD support, copy, rename and erase
                0.2.0 add backup and more tools options
                0.2.1 bugfixes
                0.2.2 quod erat demonstrandum
                0.3.0 WebIF and Wizards
                0.3.1 nl, 12 images, bugfixes
                0.3.2 tar.bz2 images, instant extract
                0.4.0 OE 1.5 and user scripts WebIF
                0.4.1 keep squashfs and Barry Allen gets fat
                0.4.2 time for a new version and new language fr,
                enigma1 plugin
                0.4.3 feeding the gnu
                4.4.0 time for a new version
                4.4.6 preliminary DM800 support
                4.5.0 DM 800 support
                4.6.0 DM 8000 support
                Thanks to noggie for his nfi file tools !
                Thanks to DarkVolli for his enigma1 plugin !
                1) Prerequisites
                During the installation there has to be CF
                card in the Dreambox (attention: insert or remove
                into Dreambox 7025 cardreader only when Dreambox
                is turned off), or an USB stick which is successfully
                detected (in case of problems try an USB Hub).
                If Barry Allen on USB is used then put
                the CVS Image from OoZooN in Flash, because this image
                has the USB drivers permanently built into the kernel.
                If neither CF card not USB Stick are attached then
                installation takes place on the Harddisk. Because
                the images then also run from there it will run
                permanently and it could be necessary that you disable
                Harddisk Standby in the images to allow running Barry
                Allen stable from Harddisk.
                2) Installation
                First boot from Flash and then copy the file
                enigma2-plugin-extensions-barryallen*.ipk
                to /tmp with ftp (TCP/IP must be working already).
                If you have an image in Flash that offers a Blue
                Pannel Manual Addon Install, then you can use this
                functionality to install the ipk file.
                If not, then install Barry Allen by entering the
                following commands in a Telnet session:
                cd /
                ipkg install /tmp/enigma2-plugin-extensions-barryallen*.ipk
                Then restart enigma2 and the Barry Allen Plugin
                shoudl show up under Games / Plugins.
                In the Images installed by Barry Allen you don't have
                to install the Barry Allen Plugin anymore.
                The Barry Allen Plugin integrates himself into then
                automatically during the image extract.
                And you can remove Barry Allen if you are booted
                from Flash:
                ipkg remove enigma2-plugin-extensions-barryallen
                3) Usage
                There is now the enigma2 Plugin of Barry Allen included
                under Games / Plugins of the enigma2 menu,
                which offers the full functionality of Barry Allen.
                For extracting of nfi images in Barry Allen copy the
                image files to /MB_Images (normally a link to
                /media/hdd/MB_Images created during Barry Allen
                installation)
                If there are Problems with image extraction or other tasks
                with the enigma2 plugin try doing it in telnet:
                cd /media/ba
                ba.sh extract nameoftheimage
                On the next reboot this new Image should be available
                in the bootmanager for choosing to boot it and then it
                can be customized and used as usual.
                The Bootmanager now should remember the last booted
                image and hence recordings from Deepstandby should work
                now.
                Have Fun using Barry Allen
                on your Dreambox !!!!
                • GeorgeN
                  • 11
                  Hallo again,
                  Thanks westkill for all the things you do for me.
                  Thanks again for the barryallen tool.
                  How do I pass this to the box?
                  I have also the same question as to how to transfer my mp3 to the hdd. You said I can use an ftp program but which?
                  I am at a loss about which application does what.
                  (which application I use to transfer images to usb, which to transfer and install tools and plugins, which to transfer mp3 to hdd, which to save settings and other things like bouquets and channel lists to pc so as to have them available if a crash or something else happens and I need to transfer them back to the box).
                  Please suggest a program for each of the above (for example: Dreamup = used to install an image to the flash memory)
                  Thanks again and sorry if I am asking things that may be silly to experienced users-owners of dreambox receivers.
                  Regards
                  GeorgeN
                  • westkill
                    • 2378
                    in the downloads theres a program called flash fxp or dcc (dreambox control centre)
                    which is a program that transfers files from your pc to the dreambox
                    on one side of the screen you will see your pc and on the other the dreambox
                    make sure your box is connected to your router or pc add the ip address of your dreambox.
                    • westkill
                      • 2378
                      when it transfers a file it copies it fro your pc to the box
                      so you dont lose the original on your pc.
                      • GeorgeN
                        • 11
                        westkill you are the best...!!!
                        I have downloaded the program and started transfering some mp3 and all the photos I currently have in digital form...!!!
                        next are my compilation of mp3s...
                        You are GREAT thanks again
                        Regards
                        GeorgeN
                        • GeorgeN
                          • 11
                          Hi again,
                          There seems to be something wrong with my internet connection-router or with the site of nabilosat because the box does not manage to make a connection again...
                          Since the last time I got connected and downloaded skins, plugins, etc, I have not made any change to anything... I just tried to connect again yesterday and download some other things again and I got the message I had been getting.
                          Note that pc and box connect ok through the router (I have already copied to the hdd of the box my photos and some mp3...)
                          I am at a loss...
                          Regards
                          GeorgeN
                          • westkill
                            • 2378
                            so you can ftp ok but no internet to the box
                            i can only think check your ip settings
                            switch the power switch off then power back up again
                            may resolve it
                            • elektronic
                              Hello GeorgeN,
                              I had a similar problem with my 7020 and Nabilo Darkstar II image. I had to change the DNS. I use opendns, and it works fine. Also check the default gateway, that should match your router address.
                              OpenDNS:
                              208.67.222.222
                              208.67.220.220
