can I flash DM7020 with dreamup
  • red devil
    • Oct 2008
    • 690
    can someone point me to an image i can flash my 7020 with dreamup, ive got nab dark 2 on it wit cam stuck on CI it wont let me change cam, tried maximo's tut but wen i connect via browser there is no option for firmware upgrade
  • westkill
    • 2378
    yes you can on all dreambox
    • ces
      • Mar 2009
      • 104
      thats a long winded process using dream up...can you not use the web browser?
      ces
      • red devil
        • Oct 2008
        • 690
        ces
        never flashed usin browser so not sure how
        • ces
          • Mar 2009
          • 104
          its the easyest & fastest way my friend....you can load any image to your stb....but why change the image in the flash...do you not have a mem stick?
          ces
          • red devil
            • Oct 2008
            • 690
            ces
            i have mem stick, do i put image on it adn how do i tell box to boot from it
            • westkill
              • 2378
              it tells you in the stickies how to flash via the webbrowser
              • ces
                • Mar 2009
                • 104
                use FW 6.03..that will let you install as many images as you want providing you have the room on the stick
                ces
                • westkill
                  • 2378
                  do you not need barry allen installed on the flash image
                  so when you install barry allen multiboot it looks for a device ,a cf card 1st memory stick 2nd then the hdd 3rdwhich ever it finds thats were you multiboot from
                  • westkill
                    • 2378
                    i didnt realize the dm7020 could use flashwizard pro 6.3
                    as the extension on a 7020 image is .nfi instead of .img
                    seeing i havnt got a 7020 i cant say
                    thats why on my 7025 i use barry allen to boot from cf card but usb is just as good
                    • ces
                      • Mar 2009
                      • 104
                      barry allan is for stb`s running E2 firmware but you can use FW on E2 stb`s also but only 6.03 version
                      ces
                      • bobon5106
                        • 75
                        have a look here this is how i did my 7020
                        hope this helps
                        bobon5106
                        • red devil
                          • Oct 2008
                          • 690
                          thanks for input guys
                          bobon ive tried ur method of flashing put command in telnet and box started to reboot and never got there...and it seems to be frozen ...so now wat ??
                          can i flash a max var image (.img) to the 7020 or is there something else i can try
                          • westkill
                            • 2378
                            you will have to flash using dreamup now m8
                            • red devil
                              • Oct 2008
                              • 690
                              Thank you westkill could u recommend an image please
