dm7020s
  • ireland-batt
    • 63
    dm7020s
    just took the plunge from tm5400 to the dm7020s should be here in the morning all being well whats the best img to cut my teeth on easy as i have always used the tm updates by usb but time to learn more it comes with gemini image installed uk
    know how to ftp ifa dreamup etc dbox /dreambox and will deffo be linking full time to my router
    have a 180 gb hard drive collecting dust and a 8gb usb stick
    technomate 5400ci+ fortec star 90cm dish and motor
    darkman patch
    dreambox 500c dk1.1
    dreambox7020s img tbc
    dbox2 sagem 2x
    commando 8.2
  • westkill
    • 2378
    have a look in the downloads
    there should be a nabilosat image there for the dm7020
    • keymaster
      • 33
      Dm7020s
      Hi
      Sorry to be on a bit of a downer the 7020s was replaced by the 7020Si, the 7020S has some bugs in the onboard network card that needs a mod done, this may well already be done on this box.
      If you try sharing and the network wont work properly thats what it is. I got this done on mine by Dreambox main dealer - I only had to pay postage.
      Good luck
      Key
      • ireland-batt
        • 63
        just came right diving in now
        darkman patch
        dreambox 500c dk1.1
        dbox2 sagem 2x
        commando 8.2
        • ireland-batt
          • 63
          1st stage looking good
          well flashed the nabilosat dark2 img ftp across some keys camds etc loaded a sat.xml and a boquet list
          tho looking at the interface it will do most of the work its self
          tho im new to the way that works is there certain cams for sats ? and do i have to load them ?when i change sat
          should of got a dm sat ages ago
          thanks for the help guys
          will link up to dish in the morning prob need a bit of a tweek as was set um for my tm5400 and will connect to home network for dl all the goodies
          any thing else i need to to ????? i used to be scared of this lmfao dboxes was my limit
          darkman patch
          dreambox 500c dk1.1
          dbox2 sagem 2x
          commando 8.2
