dreambox 7020 to move dish via vboxII help
  • pob639
    • Feb 2008
    • 224
    Has anyone got a tut on setting up a dm7020s to move a dish via a vboxII and a 36v motor at present i have to use vboxII as a stand alone pointioner to move my dish never got it set up so the dreambox can send signal to vbox then vbox to drive motor on dish when i change channels/sat just via dreambox any help or ideas
    got : db7020---vbox remote---vboxII---36vH2H motor---dish---lnb
    want : db7020---vboxII---36vH2H motor---dish---lnb
  • firestorm
    • 1550
    all i did with mine which is the same setup as yours but with a vbox1 to put the coax from the lnb into the back of the vbox then a coax from the vbox to the 7020,then i ran a 4core cable to the motor two cores for the reed switch and two cores for the motor power.I then had to set up the 7020 motor setting storing each sat.then saved the settings.Just make sure you start with your dish on 1w in order to get your arc correct.
    if you find the dreambox wont move the dish try it on the vbox controls it should move constanly not stopping(with the button pressed) if you have to press the move button again and again(it only moving in steps) you have a problem with your reed switch
    • pob639
      • Feb 2008
      • 224
      Thought the sat.xml file would have sent signal to vbox after i'd set long + lat so i've still got to set each sat up on page 2 of motor config and not use the go to xx function ?
      looks like thats my weekend sorted
      thanks firestorm
      been bringing this box out of retirement 4 last 12 months so back up n running soon fingers crossed
      • firestorm
        • 1550
        you can use the xx funtion but with a vbox is normaly a larger prime focus dish.Which has less room for error in alinemet with sats.So the manual method of storeing sat seems to give better results
