DM 7025 USB memory stick is not recognized
  • razekw
    hello everybody
    i have a dreambox 7025+ ,the image on the internal flash is OoZooN.
    i installed a copact flash and i used barry Allen for multiboot ,i also used wally west and made a swap file.
    i installed gemini 4.2 Image for trial on the compact flash.
    now everything is workink correct , but when i reboot from the gemini Image it wouldn`t recognize the USb memory sttick though when i boot from the internal Image ( OoZooN) it is recognized.
    does anyone have an idea of how to make the gemini Image recognize the USB memory stick?
    Thank`s
  • westkill
    • 2378
    when using the gemini image and goto the barryallen plugin or get to it via holding the blue button i think
    im sure in the the barryallen menus theres a option to mount the usb stick
    cant remember exactly but im sure its there somewere
    i havnt used my dm7025 for some time using the barryallen
    unless some one else has this installed who can check this
    • razekw
      Thank you Westkill
      I was away from home for sometime , i will try to look in barry allen menu`s as you said, with the hope i will find the solution there.
      razekw
