WHITE Sky Card?
  • satwino
    WHITE Sky Card?
    Hi All, does anyone know about the card reader modification you can do on the 7020 I think it concerns a resistor swap? so the White sky cards dont burn out....they run at a lower voltage?
    tia Andy
  • firestorm
    • 1550
    if you use your card with newcs you can lower the voltage by going into var/tuxbox/config/newcs.xml
    then you will see a script like this in edit mode chane the <mhz>358</mhz> to alter the voltage
    <readers name="Dreambox SCI">
    <globals>
    <listening-ip>127.0.0.1</listening-ip>
    </globals>
    <device>
    <name>SCI Lower Slot</name>
    <type>sci</type>
    <mhz>358</mhz>
    <node>/dev/sci0</node>
    <parity>None</parity>
    <reset>normal</reset>
    <export>Yes</export>
    <enabled>Yes</enabled>
    <blocksa>No</blocksa>
    <blockua>No</blockua>
    <blockga>No</blockga>
    <blockC0>Yes</blockC0>
    <carddetect>Yes</carddetect>
    <newcamd_port>15000</newcamd_port>
    <autosid>Yes</autosid>
    <pincode>0000</pincode>
    <priority>Hard</priority>
    • Jack Jumpin
      • Sep 2009
      • 31
      Will this work in a 7000 as well do you know ??
      JJ
      • firestorm
        • 1550
        yes you will be able to change the voltage buy doing this but there is a bit more to do to get the card to work there is a thread on here about it
        • www.1234max.com
          • 5
          <globals>
          </globals>
          <device>
          <type>sci</type>
          <mhz>358</mhz>
          <MHZ> is the unit for frequncy and has nothing to do with Voltage,measured in V <volts> my Friend
          • ohno
            • May 2010
            • 134
            tia Andy
            my white sly card running without problem constently for over 10 months in 7020 no mod and cccam 214 since the day it was released justblock emm and update in sly box at the moment.
