How to change a cloned 7020-Si mac address
  • rodders
    • 7
    Hi Everyone
    This is my first posting, I have discovered that I have purchased two 'cloned' 7020-Si dreamboxes from a UK site claiming to be selling originals. My problem is that when I try to use the boxes on the same network - one fails to connect.
    They both have the same Mac address!
    Is there a way to change one of the Mac addresses?
    Have tried using the DM-500 fix with an 'init' file in var/etc/ folder but it fails to change anything on reboot.
    Any help gladly received
    btw. on trying to contact the UK sellers site email - no reply suprise suprise!
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Here are telnet commands to change the mac address...
    cd /var/etc
    rm init
    echo \#!/bin/sh >> init
    echo ifconfig eth0 down >> init
    echo ifconfig eth0 hw ether 00:09:34:xx:xx:xx >> init
    echo ifconfig eth0 up >> init
    chmod 755 init
    reboot
    (replace xx:xx:xx with your own mac address)
    • rodders
      • 7
      Still no changed Mac address
      Hi Devilfish
      Thanks for the fast reply, I tried the command lines in telnet (changing the address to my new one) seemed to all be accepted but on reboot of the dreambox the router still shows the same duplicate Mac address.
      So no joy, what could it be?
      As before I can only telnet into one dreambox.
      Cheers
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Have you deleted the entry for the mac in your router config?
        Maybe change both macs on both boxes just to test.
        • rodders
          • 7
          Using a D-Link DI-524 Router
          I have the Router set to Dynamically assign IP addresses, so no Static addresses to delete. I have rebooted the router to see if anything changes - No luck.
          • satman
            • 736
            you can do directly do /etc directory on 7020? no?
            as in,, not in var
            boom!
            • rodders
              • 7
              Hi Satman
              Could you just clarify your last post, not quite sure about it
              • satman
                • 736
                Originally posted by rodders
                Hi Satman
                look in /etc for init and change it in there....
                take a look in it
                i.e cd etc and not cd var/etc
                in dm7020 openembedded you can write to /usr and /etc directorys outside /var
                boom!
                • rodders
                  • 7
                  OK I see what you mean, I'll report back Thanks
                  • rodders
                    • 7
                    I've finally had a chance to carry on with trying to change the MAC address of my 'cloned' 7020 dreambox. I've tried editing directly to the etc folder and also going through the var/etc with no luck. Everytime I reboot the box and check the MAC address with the 'arp /g' command in XP command prompt the old MAC address remains. I really need to change one of the 7020 MAC addresses to get them working together.
                    Any thoughts, the editing of the 'init' file seems to be accepted into the dreambox with no errors during input and the file is being changed.
                    Is the MAC address I'm using no good? (I've taken it from an old ISDN router that is no longer used)
                    this is what is shown in the init file.
                    *!/bin/sh
                    ifconfig eth0 down
                    ifconfig eth0 hw ether 00:09:34:e0:f6:a6
                    ifconfig eth0 up
                    does it look OK?
                    Thanks for your continued help
                    • durasoft
                      • 57
                      Hi, Just a thought but did you power down the router and restart it. Ive noticed it keeps my old device mac address in but when restarted it removed them.
                      Regards Tony
                      Sorry if this has been already mentioned
                      Humax FoxSat-HDR
                      Great HD/SD Box with 500GB HardDrive
                      Manhatton HH-120 42E-30W
                      Triax 88cm 0.3db
                      SKYBOX F3
                      HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
                      Intel Core i7 [email protected]
                      MSI R7970 Twin Frozr Boost Edition
                      • fced
                        • 13
                        Hello everybody,
                        i tried to change my DM800 mac address with this procedure, but it haven't worked for me...
                        i followed the procedure to create init file in /etc
                        after this chmoded to 755
                        here is the content of my init file ;
                        ifconfig eth0 down hw ether 00:09:34:xx:xx:xx
                        ifconfig eth0 192.168.2.3 up
                        and rebooted...
                        Mac Address is the same...
                        Nothing happened, did i missed something ?
                        • fced
                          • 13
                          may be you need to put the file in /etc/init.d
                          like this it will be executed at boot...
                          it have worked for me
