Help Pls
  • gemeosat
    • 11
    Help Pls
    I have just put my 2 cards SCT irdeto card in top slot and JSC Via 4 in bottom slot of my dm7000 but cant remember the settings i need to put in CCCam.cfg to make them work in cccam. Any one pls?
    top slot is sci0 or sci1?
  • iKay
    • Apr 2010
    • 182
    u need to insert the two lines below for each card and change the sciX accordignally.
    CAMDATA: /dev/sci0 11 22 33 44 55 66 77 88 99 aa bb cc dd ee ff
    TRY ALL CHIDS : /dev/sci0
    I'm not sure which slot is sci0 ,, but u can try by using one card ONLY in the top slot and use sci0 .. if it doesnt work then the top slot is sci1
    Note: Why dont u use Scam instead? no configuration is required.. just install the cam and enable it
