Delite CCcam switch for manual install
  • Rodbouy
    • Jul 2010
    • 1320
    I had been trying to find this plugin ever since I used it on the Dream Elite Phoenix image but to no avail.
    But finally a op Sunquick from Dreamoem gave me the files.
    Cheers for the help also Satsmo.
    Unrar and put in usr/lib/enigma2/python/plugins/extensions
    CccamSwitch.rar
  • hjalmur
    • Jan 2012
    What does this do?
    • marcus1975
      • Jul 2011
      • 248
      Originally posted by hjalmur
      What does this do?
      Hi mate, it enables you to switch between your set-up of sea lion
      So being able to pick what sea lion to be active can be a massive bonus.
      [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
      • thevilla1
        • 78
        just a quick question... how many sea lions would you want? sea lions from the same zoo? or different zoo?... if you get 2 sea lions from 1 zoo...does the dm800 automatically choose which one performs best? or would manually switching help sometimes with long pings time etc?
        • pec0sat
          • Feb 2012
          I hope to solve the problem with this plugin. I'm using now cccam info 1.3c, press menu button and switch to different cccam.cfg (cccam_1.cfg cccam_2.cfg etc) but often when I try to switch the plugin delete the meaning cccam.cfg!!!
          I can only put manually from pc the cfg file in my dreambox and reboot the decoder....
          • pec0sat
            • Feb 2012
            tryed, doesn't work.
            If I try to switch nothing happens.
            • Downlord
              • Feb 2012
              working on my box
              • Hackdroid
                • Jan 2012
                • 53
                Originally posted by Downlord
                working on my box
                what is exatly working can you explain ? are you saying that you have two lines and you can swith between the two ?
                If iv'e helped you then please click the THANKS / LIKE button !
                • rapca
                  • Aug 2012
                  now working
