Hi Rodbouy
With ref to post 3 above I have been searching for one of these cccam switches for ages.
I have one on my other DM800HD which has Dream Elite image on it and a plugin for switching between cccam config files.
On my DM800HD pro I have a Nemesis image and want to have a cccam switcher on this, will the above work on this image aswell
Many thanks in advance for reply
Hi
Thanks for reply Rodbouy, works OK with my "Nemesis DM800 Sim2 SSL84b image" after inputing it as you stated, now happy that I can change sea lions if they go down without having to switch on computer and use DCC
Thanks again, only been 12 months trying to get this done on prievous images.
Can I ask what image you are running the pluggin on?
Wondering if the pluggin is compatible with:
Dream Elite 3.0 DM800HD-ramiMAHER #ssl84b
Cheers.
I'll answer my own question as it may be useful for others to know that the above pluggin works just fine on the Dream Elite V3.0 image.
TSPanel also allows you to switch config files. I was using this for a short while.
Going in to the option with TSPanel to switch a short while back it listed the two config files. However neither of them were ticked. Usually one is and it's a simple case of highlighting the other, pressing "OK" to move the tick and then press "Activate". The box constantly green screened when attempting to tick box a config file. Fortunately the above pluggin saved the day.
