This is an ipk file..Put in on your usb or HDD and install local extensions..
1 Channel ( VOD plugin for enigma2 thousands of movies )
hi thanks for this it works great using blackhole but i cant get it to work on DreamboxUK v1.1 DM800 for Sim2.01 ssl82 by sat, i looks like the program is a bout to start then just goes to my recorded programs, do i need vlcplayer installed or need to tick somefing in the menu.
dreamuser12 -
dont need to install anything else matey..mabye the link isnt good for the movie you selected..Tip,try and choose putlocker links as these are the best by far..Here attached is also an updated version..ftp to box and over write.Go to... /usr/lib/enigma2/python/Plugins/Extensions/1channel and copy new contents and overwrite..Let me know if any better..this new version has many more providersAttached FilesComment
Simple Yes
[I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TVComment
thanks mate that its working greatdont need to install anything else matey..mabye the link isnt good for the movie you selected..Tip,try and choose putlocker links as these are the best by far..Here attached is also an updated version..ftp to box and over write.Go to... /usr/lib/enigma2/python/Plugins/Extensions/1channel and copy new contents and overwrite..Let me know if any better..this new version has many more providersComment
Ill have a look for it later and upload from my server if u want..You can then post the link in your urllist.txt & watch on ur box..you can create you own lists on urllist.txt (This is in the plugin folder on box)
It on
Code:http://www.1channel.ch
Code:http://stagevu.com/video/bbqvzpohanwb
ok mate i have edited the urllist to include the link stagevu above you provided but not showing must be doing somate wrong any ideas cheers mickyIll have a look for it later and upload from my server if u want..You can then post the link in your urllist.txt & watch on ur box..you can create you own lists on urllist.txt (This is in the plugin folder on box)
It on
( wanted that
