smargo setup dm800 with cccam213
  • willet
    • Sep 2009
    • 21
    is it possible to setup a smargo reader with this setup using gemini 11 image
    Only if the Image has the driver support for it if it does then i cant see wht not
    • willet
      • Sep 2009
      • 21
      thanks digicon
      how will i know that just plug in and see also should i be able to see the smargo on my pc if i plug it into a usb port
        thanks digicon
        You could try it in the DM and see if the image has the drivers built in if it does not i am sure they are available from somewhere, as for the PC again if running windoze it should attempt to find and download them. I know the drivers are available fro the Linux side
        • willet
          • Sep 2009
          • 21
          thanks again but where do i look to see if the drivers are there i have looked in dcc and in the dm menu but not sure what im looking for as for the pc it does not recognise the usb device and wont search for the drivers
          • willet
            • Sep 2009
            • 21
            got the driver for the pc i can see the reader now set mode to autoswitch kernel to dreambox what does the t-mode set at t=0 t=1 egt 0-255 what does it need to be set at and best clock speed fot nds how do i set the kernel in dm800
