Newnigma2-Team presents:
Newnigma2 OE1.6 dts downmix
To explain
With this plugin it is now finally possible a dts audio stream that is in many mkv containers include, without dts system simply downmix stereo speakers on the issue of the TV! This way you do now an expensive converting the audio stream to an external computer from dts to AC3 before you can watch the film.
To use the new plug is at least one or Dreambox 500HD Dreambox 8000th The dreambox-TMPD "Genuine plugin must be installed and executed at least once been successful. The operation of the "dreamdts" plugin also covers libdca0_0.0.5 Newnigma2 unstable and a current image or a current dmm experimental image is necessary. The libdca can be drawn from the unstable feed.
Known Issues
- If the plugin does not run immediately on a DM8000, please call again until the "Genuine Plugin and follow, then it should work then there
HERE:
To explain
Known Issues
HERE:
if not press the green tab to tell me to f**Koff
