SD channels not working
  • smhomer
    • Sep 2012
    Hello,
    I have scoured the web to look for an answer for my problem but have come up with nothing, I apologise in advance if my query has already been discussed.
    This is the situation, today i manually added some channels on my dm800hd which has been working perfectly with me for the last 8 months. After the channels were found and added i went back to my channel list and noticed that only the HD channels were working and absolutely none of the sd ones work.
    When i go on any of the sd channels the signal and everything else seems fine but no picture or sound. Now when ever i try to do a manual or automatic scan its shows as no services found. When i check the signal on sat finder it all seems to be good. I have spent the whole of the afternoon trying different tuner configurations but have had no luck at all.
    I would greatly appreciate any advice that can be given to me.
    If it helps the channels i added were not HD channels they were SD.
    Many thanks
