Hi everyone , my first thread didn't go down well because i mentioned the word which should never be spoken . This should be a safer topic. So I have had the very simple setup of two satellites A and B Hotbird 13 and Astra 28.2 from the beginning but i now decided to add one or two more satellites as they work through my communal satellite Astra 19.2 and/or Astra 23.5. I use a 4 way diseqc switch and have tried first with 3 satellite but with no luck as only the first lnb works every time. I initially set it up with sat finder and the 2nd lnb only seemed to get signal when i changed to manual transponder but when i zapped back the channels didn't actually work. I would be very grateful if someone would be so kind and explain to me how to do this properly , but I know that everyone is really busy and might not have time to help me step by step , so if someone could just direct me to the solution in another thread , forum or website that would be great too ,because thus far i cant find anything to help me.
THANK YOU, :
THANK YOU, :
