###guide for setting up usals for dm800###
  • floridali
    Hello everyone,
    I have a quick question
    I just got Dreambox DM800 HD and I don't know how to set up?
    I've Disecq 1.2 motor
    Lat: 51:36:34N (51.60945)
    Lon: 0:08:58W (-0.14957)
    The question is:
    How to set-up the dish positions manually?
    • why me
      • Nov 2010
      new to this sat stuff
      can anyone offer advice or point me in the right direction we live in a new build so we can not have cable as the they will not be putting this in place, so i can only have **y my questionis is what dish do i need and box can someone explain why is a dreambox sought after should my dish be motorised, if so what box do i need to buy to go with it and how do i set one up as i have been on google finding it very hard to digest !! help help please!! gary
      • standarren
        • 857
        #18
        great guide but when i change the sat position it picks up some and not others is there a way to fine tune each sat and store the position
        • FOTISCREST
          • Feb 2011
          thanx for the information . very usefyl
          • olly330
            • Feb 2011
            • 9
            #20
            many thanks
            • anhbin
              Originally posted by westkill
              GUIDE TO MOTORISED DISH SETUP DM800 TUNER FOR USALS
              Image Used -Blackhole V0.12
              If your using DiSEqC 1.2 you will have to set-up the dish positions manually. If your using USALS it should be automatic.
              Here's the USALS procedure that I used.
              First make sure the dish is correctly aligned on a satellite, eg Astra 28.2E
              Press Menu
              Set Up
              goto
              Service Searching
              Tuner Configuration
              Choose Tuner ALPS BSBE2 (DVB-S2) - Press OK
              Now for my configuration***8230;***8230;..
              Configuration Mode: Advanced
              Satellite : Astra 2A/2B/2D/Eurobird 1 (28.2e)
              Change LNB to LNB 1
              Priority : Auto
              LOF: Universal LNB
              Voltage Mode: Polarization
              Increased voltage: yes
              Tone Mode: band
              DiSEqC Mode: 1.2
              Toneburst: None
              Committed DiSEqC: None
              Fast DiSEqC : no
              Sequence repeat : no
              Command order : committed toneburst
              Uncomitted DiSEqC command : None
              DiSEqC repeats : none
              Longitude: Set this to the correct Longitude for your area.
              To find the correct longitude settings for your area go to the following website
              Bing Maps - driving and transit directions, routes, traffic conditions
              In the "Find a Map" box at the top left of the page, enter your post code.
              Select your country in the drop down box below it and click on the "Find" button.
              This will display a map on the screen and below the map at the bottom right you
              will see your Latitude information, example below for Postcode district:NE39 1
              Lat:54:55:09N (54.91913)
              Lon:1:44:55W (-1.74859)
              So in this example in the Dreambox menu you'd set
              Longitude: 001.748
              West
              Latitude : 54:550
              North
              Use USALS for this Sat: Yes
              PRESS OK TO SAVE
              Once this is set up on one satellite its easy to sort the rest.
              Go back into reception settings
              Highlight satellite and choose the satellite you want
              The example here shows Hellas on 39.0E
              Now select LNB and right to LNB 1
              This will fill in the configuration with your previously set configuration
              PRESS OK TO SAVE
              then scroll back up to satellite
              scroll left or right to another satellite
              goto lnb scroll right this will automatically set that satellite up
              keep repeating this on all satellites needed
              Thanks ...............
              • SuperSat
                • 365
                #22
                Press Menu
                Set Up
                goto
                Service Searching
                Tuner Configuration
                Now for my configuration??..
                Change LNB to LNB 1
                Priority : Auto
                LOF: Universal LNB
                Tone Mode: band
                DiSEqC Mode: 1.2
                Toneburst: None
                Fast DiSEqC : no
                Bing Maps - driving directions, routes, and traffic
                Longitude: 001.748
                West
                Latitude : 54:550
                North
                PRESS OK TO SAVE
                PRESS OK TO SAVE
                Thank you very much for this because I was looking for this kind of posts for many months and now I found it and you made my DAY!!!!!
                Thank you again!!!
                Technomate 6800 HD/DM800 HD PVR
                1.1 metre Dish
                Darkmotor
                SuperSat
                http://www.youtube.com/watch?v=kyFyAqLtHq8
                http://www.digital-kaos.co.uk/forums...0192-supersat/
                • abuahmed
                  • 4
                  #23
                  Thank you very much indeed for the info Westkill
                  Before everything, sorry for my poor English!
                  Recently I replaced my old Humax5400 receiver with DM800 hd
                  My Dish is motorized, I mean in case I'm watching NileSat (7 deg W) position (say 1),
                  and want to watch some channels from Amos satellite
                  I move the Dish using an actuator and separate positioner (SuperJack EZ Track II)
                  where every satellite has it's programmed position. (say 2)
                  My dish size 1.8 m, it has one (single) LNB which is connected directly to the receiver.
                  My Dish, It hasn't DiSEqC motor.
                  I found the difference in using Humax and DreamBox is very wide in everything.
                  My new DreamBox 800 furnished already with software Gemini Project 2
                  Available programmed satellites are:
                  Atlantic Bird / NileSat 7 deg W,
                  Hotbird 13 deg E,
                  Astra 19. deg E
                  and ArabSat 26 deg E
                  My Dreambox 800 not programmed for other satellites such as Amos, Sirius,..etc.
                  I understand that your above mentioned explanation will help me too much.
                  But I'm hesitated to do any change without consulting You!
                  Your help will be too much appreciated.
                  Please do one example for me such as;
                  how to add Amos satellite (4 deg W) for example ch2 and ch10.
                  Thanks in advance
                  • abuahmed
                    • 4
                    #24
                    Press Menu
                    Set Up
                    goto
                    Service Searching
                    Tuner Configuration
                    Change LNB to LNB 1
                    Priority : Auto
                    LOF: Universal LNB
                    Tone Mode: band
                    DiSEqC Mode: 1.2
                    Toneburst: None
                    Fast DiSEqC : no
                    Longitude: 001.748
                    West
                    Latitude : 54:550
                    North
                    PRESS OK TO SAVE
                    PRESS OK TO SAVE
                    can I use your procedure without mention Latitude and Longitude?
                    best wishes
                    • andrelondon
                      • Sep 2011
                      Multi Sat Configuration
                      Hi there
                      I would be glad if someone could help me with the multi sat configuration for my Dreambox DM800. I followed the step by step but I'm geting confused on the latitude/longitude part. Since multimap is now bing maps is not showing the lat/lon as described so the results that I've got from my postcode are:
                      51.3179580867291 -0.578015372157097
                      What are the numbers that I need to input on the dreambox? And is North/South - East/West???
                      I know the dish works as I have a technomate 5400 and it works fine but I wanted an HD one so i bought the dreambox.
                      But now all i've got from the dreambox is Tune failed. I tworked once when I selected 28.2 Astra (this was the satellite that the dish was pointing to when I was last using the technomate) but I tried to move to other satellites and all I've got is the Tune Failed message and now even the 28.2 Astra is giving me this message. It must be the lat/lon is wrong.
                      Those are the coordinates that I put on the box:
                      Longitude: 000.578 West
                      Latitude: 051.317 North
                      What am I doing wrong??
                      Thanks for the help!
                      • colinh1213
                        • Apr 2011
                        • 92
                        #26
                        when set up as in post 1, when you change over from say 4.8 bouquet to another sat in the bouquet does the dreambox move the motorised dish ?
                        • andy91
                          • Aug 2010
                          • 3583
                          #27
                          With Usals all you need to do is choose tuner as simple.
                          Mode=positioner and put in correct long and lat.
                          Install a solid set of bouquets like Sgtflipflops or Catseyes and the dish should move when you press a channel from any sat.
                          Check the picture below.
                          Andy.
                          • colinh1213
                            • Apr 2011
                            • 92
                            #28
                            andy when ive put the long an lat in how do i scan sats mate ?
                            • eddar
                              • Sep 2011
                              #29
                              if you don't have chanelles of course you have to scan otherwise you don't have to, just store a position.
                              • colinh1213
                                • Apr 2011
                                • 92
                                #30
                                i know about scanning for channels, sorry for being vague, my box wont move the dish so i can get it to scan for channels on set sats, ive started a thread to help me on this, thanks guys.
