Tut on how to fix NO CA on all DM800HD
  • bubbles69
    • Feb 2010
    • 1150
    Quick tut to repair NO CA on all DM800HD
    Please use patched version Dreamup here
    1. connect via serial using NULL Modem cable and Ethernet to router and pc.. ( if you don't have a Null modem cable you can purchase here null modem cable found EDITED.. ANYWHERE
    2. load patched version of dreamup, select your com port and then click connect and power on dm800
    3. when initialised it will display http serial mode on lcd and show dhcp ip once ip is displayed dreamup as served its purpose and now its in flashmode
    4. log into webshell on pc using the 192.168.x.xxx address on LCD disply and flash as normal
  • bubbles69
    • Feb 2010
    • 1150
    I made this quick tut for the fact that there was 1000's of posts banging on about this problem,, and no one has bothered to sticky it am I just wasting my time...
    • cloudnineuk54
      • 530
      agree this should be a sticky
      • mark36
        • 166
        bubbles your a star,just got my DM800 today and wanted to change the image and i got the guess wot code but this little bit of advice has been priceless.
        cheers mate
        • bubbles69
          • Feb 2010
          • 1150
          One day it might actually be noticed and made a sticky..!! glad it helped you and many others..
          • .: JaCkPoT :.
            Retired Sat TV Addict
            • 5607
            Sticky this thread MODS, stops alot of forum posts.
            ___________________
            In the good old days, I had
            DM800s HD
            Openbox S10
            TM500
            DM500s
            90cm FortecStar dish
            Maxx 110cm Dish
            Technomate 2300 Motors
            • nick696
              thanks............................................ ................
              • bubbles69
                • Feb 2010
                • 1150
                No probs glad you found it as it still not been made a sticky..!!
                • sfills9
                  Thank you.......
                  • SAFC_FTM
                    • Sep 2009
                    • 51
                    this should defo be made a sticky,
                    cheers mate, helped me out today after i ballsed things up!
                    • 1INSTALL.CO.UK
                      • 21
                      Will tis fix an 8000 as well?
                      DM8000HD and 90cm motorised
                      • thresomedude
                        • 18
                        I have, and have had, the problem ”no ca found”.
                        I did as the “Tut on how to fix NO CA on all DM800HD”
                        describes, but added the new image via dreamup(because webinterface didn’t find it), this image:
                        It took 1 hour. So far, so good.
                        After an hour I got the message, something like this: “everything ok”.
                        Dm800 hooked up and got the same message, “no ca found, contact the dream ....”.
                        BUT
                        I did not give up, took the power connector in and out in about 10 minutes, and suddenly it started up, and now runs dm800.:-)
                        But I am afraid to take out power and start it again ...
                        Some others who have experienced this?
                        • Louiz
                          • 35
                          Hi, I have got this problem. "Err01: No CA Found" I have tried the patched Dreamup but still cant connect to my HD800. I am using a Null cable and also both cross and Non-cross cable. Yet still got the same message. Anyone can help?
                          Anyone can tell me how to check my HD800 BL?
                          • healeydave
                            • Mar 2009
                            • 16
                            Same here, I've now lost count of how many times I've downloaded the same patched dreamup program and followed the same (re-written instructions).
                            My LCD does not change.
                            When I launch ANY version of DreamUp (I think I'm up to 6 different copies included patched), click Connect and Power On the DM800, all I get in DreamUp is "Box Type: DM800" and that's it. It does not magically assign an IP to my DM800, it does not do anything else after posting that message in the log window of DreamUP and the LCD keeps the No CA Found message. :-(
                            I have even scanned the whole IP range with DCC to see if the DM has magically gotten an IP address without any indication but to no avail, the scanner only finds the laptop IP.
                            • 1INSTALL.CO.UK
                              • 21
                              Since my last post on here i have had my dreambox replaced by the shop as its a common problem with the chip on the board
