how to flash a DM800
  • krazylegz
    • 2834
    Flashing a new firmware (image) by Browser
    What you need to flash
    You need the image file you want to flash. Image files have the extension *.nfi. You can't flash other
    images like *.img files. Don't try it - it won't work.
    You need either a DHCP server, a configured bootloader or a serial cable and a terminal program
    like HyperTerm.
    You need a browser, and a network cable. If you connect the Dreambox directly to the PC,
    you need a cross cable, if you connect trough a switch/hub/router you need a normal
    (non-cross) cable.
    To flash a new image, you can use the second stage loader. It must be present and not broken.
    The following steps assume you have a DHCP server. If you don't have one, you have to setup
    an IP address in the bootloader's serial setup.
    - Power down the Dreambox, either using "shutdown" and by removing the power connector.
    Standby is not enough!
    - (1.) Press and hold the power button. Replug the power connector into the Dreambox.
    - (3.) A text "*** STOP ***" should appear. Now you can release the button.
    The bootloader entered the "waiting" mode.
    - (4.) Above the "*** STOP ***" text, there should appear an IP-address
    (four decimal values with a dot in between). If there appears the string "dhcp" instead,
    the box still searches for a DHCP server. Wait a bit. If it doesn't change, something doesn't
    work with the DHCP server. Check wether network cable is plugged in etc. If it just doesn't
    work, set an IP using the serial terminal)
    * - Now, open a browser on your PC.
    (1.) enter in the address line "http://ip/" (where ip must be replaced with the value in the LCD).
    - (2.) on the bottom of the page, there's a link called "firmware upgrade". Click it.
    * - On the next page, you can select the flash image you want to flash. be sure that it has the ".nfi" extension.
    You can't flash other images (like .img)!
    - Click on "FLASH!" and wait. It might take some time to upload and flash the image.
    - Switch the box off again, and on again. The new image should be flashed and working.
    PS3= krazylegz120282
  • kbliverpool
    • 57
    flash
    i have done all that and got error message no ca found can you help thanks
      • Decoder
        • 46
        Hi krazylegz
        I've followed all your instructions and when it comes to this part:
        I have no bottom of the page so "firmware upgrade" isn't showing !!? It opens in one page only so I can't scroll down but when I go through the options I can see the channel list and even get the picture of the channel it's tuned to. So what am I doing wrong please?
        Only just got this box and it is quite different (well to an idiot like me!!) from my 7020.
        Great post and thanks for any help/pointers you can offer.
        • dean123
          help please
          can some one help me i want to set up a dm8oo box or one of the starview combi boxes on the internet a
          nd on a motorised dish but dont no wher to start people are
          going on about how good it is but not telling how to set it all up
          • plasterer
            • 1631
            Actually they are mate
            Read any of the red stickys at the top of the page
            There a mountain of infomation
            And will tell you exactly wot you need to know .
            Maybe your post will end up there to help others
            Great first post mate ............paul
            PAUL
            • standarren
              • 857
              help guys no ca found think i need a bootloader
              • akhamis1
                i have done all that and got an error message no ca found can you help thanks
                • z80
                  • May 2010
                  you need to make sure that the image you have chosen matches your sim revision number....
                  • shahalum12
                    i have a clone dm800, with pre installed BL76A and Gemini v5.10 will i hace CA error?
                    • karoboy
                      • Feb 2011
                      Hi guys am new to this forum but all the same i need an urgent reply
                      I'll just got this box Dreambox 800hd, But the hd channels are giving me problem like frozen and others ple what do i need to do.
                      • Decoder
                        • 46
                        Hi karoboy Well don't know where to start really mate - how long is a piece of string!!! 1. what image is it running? 2. what tuner has it got fitted? 3. are you motorised or fixed dish? 4. what signal percentage is showing? 5. does it happen on ALL HD channels or just some (and if so which ones)?
                        So assuming it's fairly new with possibly the latest "M" version tuner and you are up near the 100% mark with signal etc are you sure it's not your internet dropping out - again assuming you are not running original card
                        Before anyone can help, you really need to give more details
                        Hope you get it sorted OK
                        • scoot1690
                          • 90
                          is d800 dead
                          hi guys i have tried all the possible fixes in the stickies getting error no ca found but when i reboot the box and hold the start button i dont even get an ip address still coming up saying dream multimedia error look at www.dm7020.com error no ca found i am using a clone d800 nabilo image but have tried several images but all saying file too big anything else that i can try guys all help apopreciated
                          • aabedi
                            • Oct 2010
                            • 8
                            Guys, I had similar issue - I guess the most important thing is working out what sim you have - I have a 2.01. Once I had that I was able to use dreamup with a serial cable to install a second stage loader (I went with 76 - my dm original came with 72). Having done that - I then installed the image making sure the image matched the SSL version AND the sim version.
                            try Free Dreambox Images Download (Only for NEWB DM800 SIM2)
                            • chroneer
                              • Apr 2011
                              Can we flash the image with Flashwizard on DM800 ?
                              Can we use a better transfer application like Flashwizard for the Dreambox 800HD image update ?
                              Or other method like Barry Allens ?
                              George
