DreamboxEdit Guide
  • scooby5555
    replied
    SOLUTION
    Anyone having problems should try DREAMSET232 - Worked first time around.
    Leave a comment:
  • scooby5555
    replied
    Originally posted by reddevil157
    Right, tried this, seem's when I hit reload setting's ( this might take a few mins ) It say's command ready, nothing happens, so I waited bout 5 min's, then decided to hit reboot to see if anything happen's. Now all I have is a flashing Darkstar logo.Also cannot connect to ip now. Suppose I may reflash, any advice ?
    Ok, I was able to send my old list back to dreambox with the same method, so what am I missing? Only difference I can see, is I've got an extra box unticked ( picon's ). I've a dm 500s, set to Enigma1.
    Just had a look in expert setting's, should I have auto bouquet change enabled ?
    Thanks for the had work SGT but I get the same as above, flashing logo and have to reflash image. Tried other BOQ and they seem to be ok.
    Leave a comment:
  • porter1
    replied
    and also check ftp and telnet are enabled on the dream,thats the problem i had,great guide
    Leave a comment:
  • abu baniaz
    replied
    When I open dreamboxedit, I only get two panes. I don't seem to get the bouquet pane. I can transfer to the STB without a problem.
    Could someone point out how to enable this pane. I'm using version 4.0.1.0
    Many thanks
    Leave a comment:
  • MR-T
    replied
    this should be made a sticky,as i have used this for months and found it very useful indeed,as it saves time tunning all then sats manually.
    Leave a comment:
  • RuberDuck
    replied
    Originally posted by goose68
    When you open the advanced tab make sure you have the allow duplicate entries in bouquet tab ticked.
    that only really applies to bouquet packs such as the B16MCC pack so that it follows the sky uk channel listing.
    Leave a comment:
  • SGTFlipFlop
    replied
    Makes no difference that
    Leave a comment:
  • goose68
    replied
    Leave a comment:
  • reddevil157
    replied
    Leave a comment:
  • SGTFlipFlop
    started a topic DreamboxEdit Guide
    DreamboxEdit Guide
    Here is how to upgrade your Dreambox with the latest up-to-date Bouquets, Using the App DreamboxEdit (Found In The Download Section) All you need to do is manually edit your Regional channels (BBC & ITV) Info on how to later in tutorial.
    Step 1 :- Open DreamboxEdit
    Step 2 :- Now click Options Logo or (Tools > Options)
    This section will appear, OK time to insert your Dreambox details (Only need to do this once).
    IP of Dreambox :- Whatever your IP, Your Dreambox uses to access the Internet (Usually found in Network settings on Dreambox)
    Username = root | Password = dreambox | These are the default settings input as I have or unless you changed them manually enter what you changed them to.
    Enigma1 = Dreambox 500, 600, 7020 Users Click Satellite Receiver (Grey Box - Right Hand Side) then file path should say this :- /var/tuxbox/config/enigma/
    Enigma2 = Dreambox 500 HD, 800, 8000 Users Click Enigma2 Settings (Grey Box - Right Hand Side) then file path should say this :- /etc/enigma2/
    Click on Advanced Tab and make sure Display 'Reboot Dreambox' option on FTP screen is ticked
    Click save and thats you done with this bit.
    Step 3 :- Now click Open Icon, or (File > Open) Browse your Downloaded Bouquet and click OK, Will Look like the image below
    Changing Regional Channels, Find your Regional Channel and drag it across from left column into the middle column and delete the one you don't want (Do this for BBC & ITV channels) make sure you click save.
    Step 4 :- Ready to send files to Dreambox now. Click FTP icon or (File > FTP)
    First set out exactly how I have Untick all 3 boxes at the bottom left.
    Select IP Settings Set :- Make sure the profile you created is chosen.
    Now click 'Send Files To Dreambox' Let it do its job, It should say complete.
    Next click 'Reload Settings On Dreambox' Again let it do its job, It should say complete.
    Finally click 'Reboot Dreambox' and by now your new settings should be uploaded to your Dreambox
    The End.
    Last edited by SGTFlipFlop; 6 December, 2011, 22:21. Reason: Updated guide due to DBE change
