DreamboxEdit Guide
  • youssef90
    replied
    Sorry when i have done all of this i reset the box go to bouquets everything is there but when i click on one of the channels to watch it says service could not be found..am i supposed to be pluggin this into my foxtell satellite antenna or just run it of my internet cable?
    Also i noticed that the bouquets are for astra settings..my dish is set to the optus side?
    Leave a comment:
  • Rodbouy
    replied
    Originally posted by Sat7Supplier
    how do i send bouqets to dm500?? where is the button.
    goto options and change the sat path to satellite
    Originally posted by youssef90
    Hey
    do you have to connect your satellite antenna while doing this?
    No. you just need a network connection.
    Leave a comment:
  • youssef90
    replied
    Hey
    Leave a comment:
  • Sat7Supplier
    replied
    Leave a comment:
  • lefty940
    replied
    yes they def do use it for the tm
    Leave a comment:
  • lefty940
    replied
    ha ha i think thats what they use to load boquets better read some more i think thanks
    Leave a comment:
  • SGTFlipFlop
    replied
    Not sure about a TM, Never owned one, Didn't even know this software worked for those boxes LOL
    Leave a comment:
  • lefty940
    replied
    yes loads of times im going to use it for a technomate tm 600, do i need to use the ftp option and take my files from the tm first?i dont want to cock it up
    Leave a comment:
  • SGTFlipFlop
    replied
    Tried closing down DBE and retrying?
    Leave a comment:
  • lefty940
    replied
    Hi im having a problem with dreambox edit,when i try to open a boquet i keep getting error message no file called services.any idea what im doing wrong ive tried all ways thanks
    Leave a comment:
  • mikk
    replied
    db edit bouquet problem
    When I choose the flip flop bouquet there are only two channels there? Its doing something as the fta channels are in the right order if not numbered correctly, and the epg is screwed up too, or do I need a seperate file for that, any ideas?
    Obviously I'm thick, not working at all now, file transfers but remains in alphabetical order on box??
    edit;come in tonight, booted up & hey presto, all correct. All it needs now is a good cline, any suggestions ?
    Leave a comment:
  • nazak47
    replied
    I follow all the guide but when it comes to the part "send files to dreambox i hit it and the following error
    i pull the socked from the dreabox and let it restart wen it does everything is the same, also tried rebooting from the menu but same thin
    where am i goin wrong?
    Leave a comment:
  • barrowmanandrew
    replied
    thanks for the guide, i'm having problems trying to get it work..
    i have followed the instructions, but when i start the ftp i get an error message.
    the box does connect and password etc are correct....
    anybody no where im going wrong?
    i am using commando image if that makes a diffrence
    i finally got it to work
    i used bouquet wizzerd and choose neutrino in firmware setting, ftp working now..
    Leave a comment:
  • markshore
    replied
    Originally posted by markshore
    Hi great bouquets but having some trouble with mine i have modified them for use with air video for iphone by adding another bouquet to yours have ticked allow duplicate entries in user bouquets in settings.
    Opened dreambox edit and opened your latest bouquet, opened tools and went to compare loaded services with services from dreambox selected all and updated active file set (showed the changed new frequency for MGM HD as delete?)thought it worked but no it has not any ideas as to where i am going wrong.
    Regards
    Mark
    Hi anyone any ideas as too where I am going wrong or how this should be done to preserve my modified bouquet, just read in the first post that the Dreambox needs to be re-booted after sending the new bouquets mine always shows the correct info so perhaps that is where I am going wrong with my modified bouquets.
    Regards
    Mark
    Leave a comment:
  • greatcapp
    replied
    Would anybody be able to figure out where I'm going wrong here?
    I can follow the tutorial, and after rebooting my DM500 I can see the imported bouquets, but If I select any of the channels that show up in the new bouquet, then I just get a blank TV screen. It seems that the information of the imported bouquet doesn't match up with information I have on my box.
    On my box, If I select "User bouquets" and then "Satellites" (green button), I can select Astra, then scroll through to see all the channels that are available, but for instance BBC1 London shows up and works as number 2289, but under the bouqeuts I've loaded on, it shows up as 1 and doesn't work.
    I'm struggling.
    EDIT
    I should point out that I'm on Jade PLi just in case that helps.
    Thanks.
    **EDIT**
    Figured it out myself. From my initial setup, when doing initial transponder scan, I'd been scanning 19.2 and not 28.2. Not sure why it still found channels, but it did. Still, all ok now.
    Leave a comment:
