image for bootloader 75 Dm0800hd
  • browno
    • Aug 2010
    • 176
    hi,
    I am after a clone image for dm0800hd bl75 sim 2.01.
    Can any one recomend a decent image, also how do i install
  • reaper101
    • 80
    can you not just update the bootloader
    Digital Kaos - Downloads - sim201 84a & 84b bootloader
    i did this and went on the nemisis 2.4 image
    use 84a reboot then 84b
    turn on the dreambox but only till you see the ip address then type that ip into your browser then scroll down and update firmware (bootloader first 84a then 84b then the image )
    • browno
      • Aug 2010
      • 176
      is there a list of instuctions on how to set this up...installing camm etc...
      I am a totaly newbie and have never flashed a dreambox
      • browno
        • Aug 2010
        • 176
        is this image for a clone.
        • reaper101
          • 80
          have used this on my clone
          Flashing a new firmware (image) by Browser
          What you need to flash
          You need the image file you want to flash. Image files have the extension *.nfi. You can't flash other
          images like *.img files. Don't try it - it won't work.
          You need either a DHCP server, a configured bootloader
          You need a browser, and a network cable. If you connect the Dreambox directly to the PC,
          you need a cross cable, if you connect trough a switch/hub/router you need a normal
          (non-cross) cable.
          To flash a new image, you can use the second stage loader. It must be present and not broken.
          The following steps assume you have a DHCP server. If you don't have one, you have to setup
          an IP address in the bootloader's serial setup.
          - Power down the Dreambox, either using "shutdown" and by removing the power connector.
          Standby is not enough!
          - (1.) Press and hold the power button. Replug the power connector into the Dreambox.
          - (3.) A text "*** STOP ***" should appear. Now you can release the button.
          The bootloader entered the "waiting" mode.
          - (4.) Above the "*** STOP ***" text, there should appear an IP-address
          (four decimal values with a dot in between). If there appears the string "dhcp" instead,
          the box still searches for a DHCP server. Wait a bit. If it doesn't change, something doesn't
          work with the DHCP server. Check wether network cable is plugged in etc. If it just doesn't
          work, set an IP using the serial terminal)
          - Now, open a browser on your PC.
          (1.) enter in the address line "http://ip/" (where ip must be replaced with the value in the LCD).
          - (2.) on the bottom of the page, there's a link called "firmware upgrade". Click it.
          On the next page, you can select the bootloader / flash image you want to flash. be sure that it has the ".nfi" extension.
          You can't flash other images (like .img)!
          - Click on "FLASH!" and wait. It might take some time to upload and flash the image.
          - Switch the box off again, and on again. The new image should be flashed and working
          • browno
            • Aug 2010
            • 176
            i have now installed image...sucess but when i goto download addon to get Ccam2.1.4 it wont connect..
            I have tried doing this manually and put the zip file in tmp on dreambox but it dont see it .help please...
            • reaper101
              • 80
              cccam 1.4
              make sure that the box has got correct ip and is connected
              test network settings
              i installed the ts panel
              google this
              if you cannot find i will upload for you
              download this
              ftp to /tmp
              goto manual install ipk file
              this will install ts panel to your image
              update the ts panel to 6.1
              now you will be able to install your cccam 2.1.4
              • BIKERDUDEDAZ
                • Oct 2010
                BOOTLOADER
                HOW CAN YOU TELL WHAT BOOTLOADER YOU HAVE ON YOUR BOX ?
                • johny48
                  • 50
                  Hi M8
                  (take the caps off as its like shouting when you post like that and other members may take offence)
                  as for the bootloader it tells you on the lcd of you box when its booting up.
                  cheers Johny48
                  Here is some more info on finding the Bootloader in this post
