Nabilosat Enigma2 Black Hole - DM800 v0.10
  • bb1974
    • Dec 2011
    #16
    I have prb seeing these stages through.
    This is the device information I get through the browser.
    Product Name DM800
    Booloader version Dreambox Second Stage Loader BUILD #76, built 20100419
    Flash Size 64 MB
    Production Date (YYYY/MM/DD) 2011/06/02
    mID 13
    I am trying to boot the "NabiloBlackHole_DM800_010.nfi" file through the browser.
    - I disconnect power cable. Press front gray power button and connect back cable.
    - Front display shows ***STOP*** and my IP.
    - I enter IP in the browser and get to the Bootloader Web Interface.
    - I press Firmware Upgrade and select my upgrade file.
    After doing these, nothing happens. It does not say on my browser screen (Mac computer, Firefox) anything. Pressing the button makes no change or gives no message on screen to indicate that pressing the FLASH button has starting any process.
    Same applies to the TV screen (naturally) and the display on the DM, where it still shows the IP and ***STOP***. I suppose this means that it is actually NOT flashing, right?
    I left it this way for about 5 minutes or so and nothing has changed. What am I missing???
    • abr
      • Aug 2010
      • 108
      #17
      Product Name DM800
      Flash Size 64 MB
      mID 13
      what browser are you using
      i had a similar problem not long ago
      although not with the image you require
      i always use firefox but it would not upload the file
      i tried internet explorer and my new image uploaded without any problems
      • bb1974
        • Dec 2011
        #18
        I used Firefox 8.0.1 on Mac and also tried Safari. Both same...
        • abr
          • Aug 2010
          • 108
          #19
          know nothing about mac's
          but can't you try to run IE on mac???
          • nobby
            • 205
            #20
            hi at the moment i,m useing blackhole 133d sim 201 bl76c is the imAGE BETTER than this 1 all so if i flash will it work on my clone with out doing the bootloader thing thx
            • abr
              • Aug 2010
              • 108
              #21
              i was using
              DreamElite BH_DM800_133D_ssl76a.nfi. installed on mine,
              then i updated with
              Sat4fun-Dreamelite-BlackHole_PHOENIX_DM800HD-SIM2-SSL84.nfi
              i did try to use firefox but it failed to upload,had to use ie
              it was a straight forward update using web browser
              • nobby
                • 205
                #22
                whats the better image dream elite 133d or Dreamelite-BlackHole_PHOENIX_DM800HD-SIM2-SSL84.nfi or Nabilosat Enigma2 Black Hole dm800v 0.10 as im running dream elite 133d now
                • kedarnathin
                  • Apr 2012
                  #23
                  Hi I have dm800hd pvr with ssl 82 black hole 010 working ok but can not find eurobird 9E
                  Any help please
                  • DJSimo
                    • 453
                    #24
                    Any help please
                    Could you explain a little more, do you mean it is not listed in your satellites list? if so you need to update your satellites.xml, or do you mean you are getting no signal from this sat??
                    • IanJ1965
                      • Aug 2011
                      #25
                      Apologies for jumping in here,
                      My DM800 HD has "Nabilosat Enigma2 Black Hole" on it (Official box, bought 2nd hand with this image installed) and I'm looking to upgrade to the latest version because I'm finding that despite my EPG saying it has updated the cache successfully with thousands of titles they don't actually make their way to the EPG. All I've got is now & next on the channels I've viewed and loads of gaps elsewhere...............tearing my hair out!
                      1. How do I find out what version I'm running.
                      2. Where do I download the latest version.
                      3. If I upgrade using the browser method will I lose all my existing settings?
                      Anything else I should know.
                      Sorry for the newbie questions.
                      Ian.
                      • mickydibble
                        • 2166
                        #26
                        got this image on my box but language settings wrong,where in menu is the language
                        • NICETOBNICE
                          • Nov 2011
                          • 551
                          #27
                          really loving this image guys but one thing can i set it up so it shows me the sat signal on the info bar
                          • NICETOBNICE
                            • Nov 2011
                            • 551
                            #28
                            has someone sucessfully done a manual install with a ipk file cant get this to work
                            i'm also having issues with the epg ?
                            • crazymacx
                              • Aug 2012
                              Reboots
                              Dreambox reboots all the time after about 15 sec,why? any tips?
                              • andreasacis
                                • Aug 2012
                                keep up the good work
