Hi I was looking for the Nemesis v.2.4 image for DM800HD Clone Enigma 2 Sim2.01 #SSL84 ... I have found a few online but none of the links seem to work for download. Anyone got this image can help me out? Much appreciated
Nemesis Images for DM800HD Clone
you can still get pretty much newer images for your box and your SSL although most are now running either C or D SSL which supports the OE2.0 patched drivers.
when you flash the image just make sure you flash a new Bootloader SSL first say D and then dont reboot and flash the new image
Any idea where I can find this new bootloader?you can still get pretty much newer images for your box and your SSL although most are now running either C or D SSL which supports the OE2.0 patched drivers.
when you flash the image just make sure you flash a new Bootloader SSL first say D and then dont reboot and flash the new imageComment
OK, done a wee bit of research, the image im looking to install is this:......................................... From what I gather, this requires.................. and that I install this by normal flash as you would do flashing an image, right? However, there is 2 files with the bootloader, a bin file, and nfi file... Could anyone shed some light as to what the procedure would be to installing this? Appreciated.Comment
Ok if you go into the Dreambox Images Section in the Downloads i have Uploaded both the 84B ssl and the Nemesis 2.6 image the only one i could find
84b SSL: sim201_ssl84b - Downloads - Digital Kaos
Nemesis 2.6 Image: Nemesis2-6-dm800-SVN-107r5-ramiMAHER - Downloads - Digital Kaos
Ahh thanks a lot man, what a guy! So I just flash the SSL in the same way that I would the image?Ok if you go into the Dreambox Images Section in the Downloads i have Uploaded both the 84B ssl and the Nemesis 2.6 image the only one i could find
Nemesis 2.6 Image: Nemesis2-6-dm800-SVN-107r5-ramiMAHER - Downloads - Digital KaosComment
You will have to search around for TSpanel as i am unsure if they carry this as an extra on the Plugins menu, if you want to run a later version then you would have to upgrade the SSL again with a newer image. I put TSimage and SSL 84d i the download section which has everything anyone needs from there download section when the image is installed
