Green Screen of death
  • billy0911
    • Dec 2012
    • 18
    I've had a skybox f3 and it a good starter box,
    I've just moved up to dream box 800HD,
    while I'm getting the GSOD the box keeps restarting, I can connect to the box via flash fxp,
    any help would be fantastic, and thanks in advance.
    Admin if this is in the wrong section please feel free to move it
  • gaelicred
    • Feb 2013
    • 49
    Did the box go to gsod from the time you flashed the image ? If so you might want to check the sim +b/l and reflash
    If not when did it last work ? you may have recorded something so try and boot with your hdd or usb attached
    Did you add a new plugin ? your memory may be full
    • WOODWARD395
      • Apr 2010
      • 628
      re-flash with another image I believe you may have saved your epg to flash memory or similar. and make sure you have flashed image for correct sim.
      Education is not the learning of facts, But the training of the mind to think
      So hit the thanks button if I have enlightened you.
