Hello ppl this is my first post here and I have been searching this website for information all day long.
I just got a 800HD se box that got NO CA FOUND msg on its display. I found out that this means that there was probably an attempt to flash box with wrong image. So I did a little digging and after various errors i succesifully came pass point nr .4 in this tutorial http://www.digital-kaos.co.uk/forums...und-se-226880/ I had to use dreamup instead of sunflush
I managed to get box in http mode. I tried at least 10 different nfi files. some with SSL 82 some with SSL 84 to try to load "original" version whatever that means. From what I understand if it is 800SE its sim 2.1 and if it is regular 800 its sim 2.01 so I stick to 2.1 sim all the time.
I also tried what someone suggested not to reboot from webbrowser after nfi image has uploaded 100% but to manually plug out power ( if that is what reboot means ). and whatever I try when I put power back on I get same NO CA FOUND msg on display. So PLEASE help me fix this...
1. Do I need to upload correct SSL first
1.1. If yes, is it then that I chose which image file I upload trough dreamup or do I use webbrowser again =
2. How do I find out which SSL I need to upload if I only have receiver in front of me ?
3. I read that there are images that have this SSL included so that U basicaly need ( again if I undertand it right ) to just upload 1 file tha will take U trough different stages )
THANK YOU VERY MUCH for your time
P.S. If I got any of procedures wrong let me know
