Open aaf
  • roblfcx5
    • 239
    Open aaf
    I'm running open aaf and when I'm setting a timer to record it green screens saying error and shuts down on me
    Any help on this to stop it from happening
    Maybe remove some unused plugins, would solve the issue ?
    Try a different image if that cures it then problem solved if it does not then its a possible problem with the Clone 800se or even the Hard drive itself
    • roblfcx5
      • 239
      I will do a reflash, I'm just figuring out wich image would be best to use
      Openpli or newnigma seem to be the most rated, but for some reason
      I'm putting IP address into browser
      And All I keep getting is dreambox web control centre, tried diff browsers same thing.
        Boot the box from cold and hold in the mini-flashup button on the rear of the unit until you get the IP address on the small LCD display
        • roblfcx5
          • 239
          Yes I'm doing this m8 holding mini flash until
          **stop** appears then IP address appears, I then open browser
          Add the IP
          And it just comes up same
          Dreambox webcontrol
            Clear all that Crap off the Laptop then LOL
            You can flash it via the Mini USB cable as well
            • roblfcx5
              • 239
              Haha yea I will clean more of, but what I have removed made lappy a lot Quicker
              I will remove all iTunes stuff as its not needed & it takes up a lot of memory, but I still dnt think its gonna wrk
              What usb cable would I need ?
                USB to Mini USB
