SIM2 backup uk OpenPLi-4.0-beta-dm800se #ssl84d + latest dmm drivers
  • southpaw
    • 2233
    #16
    weird, getting same here now you pointed it out, will try find a fix today mate
    fix, it seems to be a glitch with this specific version of C((@m , download a diferent version , menu- plugins - download plugins - softcams . (best practice to reboot after download).
    then to switch versions blue button- green - use right arrow to scroll to new version - then click the restart (@m button
    your ecmt!mes will now display on infobar
    • stonewall
      • 42
      #17
      Mate,
      For some reason unable to download a C((@m from the download menu. I get a error message.
      Regards
      stonewall
      • rigsby71
        • Mar 2009
        • 676
        #18
        Originally posted by southpaw
        Thanks for feedback rigsby, did you notice an improvement in pic quality or was that just placebo and my dodgy mince pies? just for clarity sake, I didn't create this image, its the excellent work of Mr GJStroom over at sim2 team HQ , I just tweaked the image to my liking, unbloated language packs and created a backup .
        I've not had my dm800se set up for a few weeks so can't recall if the picture is better than before, also, it's now set up on another tv, but the picutre is very good non the less. Great Image though.
        • rigsby71
          • Mar 2009
          • 676
          #19
          When i loaded up this image, i instantly downloaded 2.3.0 & didn't use the onboard 2.09 version so i haven't experienced the problems mentioned.
          • tassos
            • 33
            #20
            Hi can you tell me if this image is compatable with a clone Dreambox800se HD 84b. I always used 1.6. images. thanks
            • southpaw
              • 2233
              #21
              If it's sim 2 800SE then yes, just follow the instructions regarding the 84d upgrade
              • tassos
                • 33
                #22
                Image e2
                Hi I do not know the difference between 1 and 2 D800se, and when I install images I use a program called Optiflasher, do you know it? thanks for your time
                • southpaw
                  • 2233
                  #23
                  yes , I am aware of optiflasher, however you don't need a complex programme like that, just a simple web browser is all you need, and yes your box is sim2 type sim if it has 84b image on so perfectly compatable with this image, just follow the instructions in post 1 .
                  • tvbors
                    • Jun 2011
                    • 20
                    #24
                    Which skin is used on your image mate as I like it and want to install to my box?
                    Cheers
                    • southpaw
                      • 2233
                      #25
                      Cheers
                      the skin is PLiHD mate
                      • mike33
                        • 34
                        #26
                        Hi,hoping southpaw can help me or anybody else,downloaded this image which is excellent but trying to put any plugins on the dreambox seems to be a problem as the box is not seeing any at all when box as been rebooted.
                        I presume you go through software management and then install local extension but nothing appears,any help appreciated.
                        • digicon
                          • 8261
                          #27
                          You FTP the plugin to the /tmp folder and then install it do not reboot the receiver until you have installed any plugins as you will lose them
                          • mike33
                            • 34
                            #28
                            Ok digicon will try that thanks,but would this method also apply to plugins that need to be send to usr/lib/enigma2/python/Plugins/Extensions.
                            • mike33
                              • 34
                              #29
                              All sorted now thanks.
                              • southpaw
                                • 2233
                                #30
                                on this pli image, I send my ipk files to media/usb and install with software manager plugin, as they will reside on usb until deleted so there their as a backup incase of things going tit$ up
