wifi issues with open pli 4.0
  • doeflax
    • Jul 2011
    • 4
    ok, here goes guys. Does anyone here know of a good stable image they can recommend for a dm800hd se box with wifi inside ?
    I'm currently using Open Pli 4.0 but no matter how I try, the box just won't see the wifi connection at all.
    Any of you guys know of a decent image that supports wifi inside ?
  • bujar
    • Oct 2014
    @doeflax
    Try to install newnigma2-lean-dm800se-v4-0-11-ramiMAHER-#84d.
    If you'll face difficulties connecting wifi after installing image, try to install the following drivers which are available on the online feed:
    ipkg install kernel-module-carl9170
    ipkg install kernel-module-rt2800usb
    ipkg install kernel-module-rt73usb
    ipkg install kernel-module-r8712u
    ipkg install kernel-module-zd1211rw
    ipkg install r8192c
    ipkg install wpa-supplicant-passphrase
    reboot
    • doeflax
      • Jul 2011
      • 4
      many thanx bujar. Will take your advice and give this a go on the weekend.
      • amazis
        • Dec 2014
        • 6
        hi bro, i have dm800HD se wifi & the wifi work fine in my OPENPLI4 image
        • amazis
          • Dec 2014
          • 6
          im using gjstroom image OPEN PLI4 ,1st time i get wifi but no access & after few research i update the OPKG (of corse after this =Code:
          sed -i '/Package: dreambox-secondstage-dm800se/{n; s/84-r18.0/84-r18.0.0/g;}' /var/lib/opkg/status
          restart & wifi work fine till now
          the link of the image http://dreamoem.com/showthread.php?8...jstroom/page72
          look 1page for downloading
