SuperSim Japhar DM800HDse : OpenPLi 4.0 for Japhar NC3 Sim - SEPTEMBER 2015
  • toysoft
    • 752
    OpenPLi 4.0 for Japhar Sim NC3 DM800HDse, with latest IPTV software working at the best, including 700 channels ! Download link below. Enjoy !
    MEGA Link : https://mega.nz/#!EdtRUToR!ppswZItln...OHPk8v_r3YrBWA
    By MastaG for Japhar Team
    Thank you !
  • toysoft
    • 752
    VU : OpenPLi 4.0 with IPTV (More than 800+ IPTV FREE Channels) by MastaG and Japhar Team
    Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
    Changes since previous release:
    - mx3L's gstreamer revert which fixes mp4 playback from remote locations
    - Spark drivers updated to 20151113
    - Using aio-grab from oe-alliance which includes fixes for sprak receivers
    - New Japhar IPTV List (thanks to ToySoft).
    - DM8000 has no more gsod's now (thanks to ToySoft for testing!)
    Changes compared to openpli-oe-core gst-1:
    - Ships with gstreamer upstream master git:
    Using the same patches as openpli-oe-core gst-1 with only these changes:
    Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
    because this patch was already checked in upstream.
    Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
    By mx3L which fixes mp4 playback from remote locations.
    - Every receiver uses christophecvr's multibox dvbmediasink.
    - Using libtrmp and rtmpdump from oe-alliance.
    - Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
    These are only applied for Dreambox receivers.
    - AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
    - IPTV Player from samsamsam included (thx to Athoik for the recipe).
    - Large list of public IPTV streams included thanks to the Japhar Team.
    - Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
    - DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
    added si2166b blindscan support
    - Spark images includes the pti.ko from OpenATV so softcam's should work now.
    - Using aio-grab source from oe-alliance which includes fixes for spark receivers.
    - The 2.6.18 kernel will now always pass the vermagic check when loading modules.
    Now you can try and load any kernel driver from OE1.5 to 2.0.
    Known issues:
    - DM800 first boot will take a while, please be patient. The next boot will be faster.
    - On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
    We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
    - On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
    Because sometimes it doesn't scale back to fullscreen.
    I've included the MX-HQ7 skin for use as workaround.
    - On Zgemma Star you cannot use fullHD skins.
    This is a hardware/driver limitation.
    Please don't try it, it will crash enigma2.
    - Some Dreambox remotes behave very sensitive.
    This causes button presses to register multiple times instead of just once.
    As a workaround you can adjust the key interval:
    Go to: Menu - System - Input devices - dreambox remote control (native).
    Set "Change repeat and delay settings" to yes
    Set "Interval between keys when repeating:" to 200ms or 300ms.
    Press green button (OK)
    Now set the same delay for: "dreambox advanced remote control (native)" as well.
    To find the download link, search for MastaG Japhar OpenPLi 4.0
    Enjoy !
    • toysoft
      • 752
      Japhar DM Sim :
      - DM8000HD+ :
      MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
      - DM800HDse+ :
      - DM800HD+ :
      - DM500HD+ :
      • toysoft
        • 752
        Changes :
        - Gstreamer 1.7.1
        The mp4 playback from remote urls has been fixed upstream so no more revert for that.
        libsoup http-handler has been updated so also no revert for that as well
        - New libsoup handler for http urls
        - New winter logo
        - More free space laugh
        Ive added a dirty hack that will upx compress the binary before package_write_ipk
        We now have 2 to 3MB more free space (very nice, great success)
        - New xvid/divx5 bitstream unpacker by mx3L, this should fix avi files with wrong fourcc
        - The usual batch of dvbmediasink fixes by christophecvr and mx3L
        - Wifi drivers have been refactored a bit, I dont auto-load the rt7777 anymore.
        it should kick in when you plugin your wifi stick.
        If not then Ill create a ppanel which will allow you to choose which driver you want to use: rt3070, rt55xx or rt7777 (since they cant be loaded at the same time)
        by MastaG
        DM8000HD: https://mega.nz/#!YRklVADa!jfV_0mM-6...zLFubOFmA7VCAg
        DM800HDse : https://mega.nz/#!BAtCwQ4R!r15VnQlfK...nDNfLsp9CQBYbU
        DM800HD : https://mega.nz/#!kYlVHRoD!pWuty-xvl...6iGabO8Dk77bno
        DM500HD : https://mega.nz/#!VMcAyQwC!Z4CxifG_3...GSS8MW90MLYBkc
        Feel free to post images on all your satellite forums you like and share with all your friends these excellent tools and new images with full IPTV support, the best around, even better than on original boxes !!! Thank you !
        • toe471
          • 254
          Hi guys!
          Just flashed this image tonight on my dm800se, all went well but when I set my tuner configuration to 28.2 then did an automatic scan its not picking no channels up? My dish feed has good strength and that so don't no wat it could be? I tried another image yesterday and that was fine.
          • toysoft
            • 752
            Is your box having a Japhar sim ?
            TS
            • toysoft
              • 752
              OpenPLi 4.0 IPTV GStreamer 1.8.0 by MastaG (v16)
              Changes:
              - Gstreamer 1.8.0 stable release
              - New PLi spring logo
              - Upgrade OpenVPN to 2.3.8
              - Upgrade OpenSSH to 7.1p2
              - Upgrade OpenSSL to 1.0.2g
              - Patched and bumped Python due to OpenSSL not supporting SSLv3 anymore
              - Upgrade Japhar-IPTV list to 1.6
              - Upgrade rtmpdump from oe-alliance and let it provide librtmp as well
              - Upgrade ffmpeg to 3.0.1
              - Patch for dvbmediasink from mx3L for writing PTS on every PES header
              This could possible fix some m3u8 streams freezing
              - Removed the patch for dvbmediasink which should fix seeking in some mp4 streams
              Since I couldn't reproduce the problem
              - Rewrote Dreambox kernel recipes which should fix certain models not booting
              - Fixed CrossEPG
              - Fixed very large Packages.gz on the server
              - Merged latest openpli-oe-core changes
              - Merged latest OpenPLi enigma2 changes
              - Upgrade oscam to rev 11225 and applied joeuser's latest tryfix oscam-emu patch
              Emulating PowerVU should now work for multiple pids
              - Lots of stuff I forgot...
              DM800HDse+ : https://mega.nz/#!MENwRaDb!AsZrkisSZ...xNqWFWFnzz0gLA
              • toysoft
                • 752
                OpenPli 4.0 IPTV by MastaG / Japhar Team with 1200 FREE IPTC Channels and with GStreamer 1.9.0.1 (April 15th 2016)
                Changes:
                - New gstreamer 1.9.0.1 recipes based on christophecvr's github (small changes for PLi4)
                - Upgrade glib2.0 and some other components like gobject-introspection to satisfy the new gstreamer recipes
                - gstreamer1.0-libav is built using it's minimal libav with only support for wma (thank you chris)
                It's pre-installed on all receivers except for the ones with only 64MB of flash (dm800/800se/500hd)
                - Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Player's exteplayer3 (thx to Taapat for the original bbappend)
                Login with telnet and issue: opkg update && opkg install ffmpeg
                - Latest openpli-oe-core changes
                - Latest enigma2 changes
                - spark: libeplayer3 is pre-installed now (also in the feeds) for movie players with support for this library
                Note: servicemp3 still uses gstreamer
                - spark: some OpenPLi enigma2 backports (since Taapat doesn't maintain his enigma2 branch anymore)
                The servicemp3 memleak patch has been applied with some other patches/commits I found useful
                - spark: don't force async mode on the dvbaudiosink anymore, it's now the same as all other receivers again
                - Add Vu+ Solo 2 Lonrisun V4 (v1 and v2) images + feed
                DM800HDse+ : https://mega.nz/#!AwhlABgI!47Lh28i8H...iTBmgGQhBiK3jU
