enigma2 TSpanel plugin,everything you need for your image
  • shiplu
    • Aug 2011
    • 17
    #106
    Hi mfaraj57
    I like to request a new feature on TSpanel, only if its technically possible.
    In settings loader in systems tools, It would great if there was a setting that prevents overwriting certain selected channels in a bouquet. for example regional channels for ch1, ch2 etc.
    I have feeling it might not be technically possible but its worth asking.
    • mfaraj57
      • 557
      #107
      Originally posted by shiplu
      Hi mfaraj57
      Hi mate
      good idea and i think it is possible
      see if i can include in next update
      • mfaraj57
        • 557
        #108
        TSpanel 4.1 complete refrence for enigma2 box user
        updates:
        -added new addons server dreambox packages from oozoon image server
        -removed ferrari addons server from default servers
        -Due to incompatibility of TSpanel with ferrari addons manager the later uninstalled automatically during TSpanel installation,still ferrari users can use TSpanel by installation of attached TSpanel-ferrari useraddons.ipk,TSpanel offers more options to user than unupdated ferrari addons manager
        -Fix minor bugs in spinner preview
        -fix lsk addons server source url
        Installation
        copy attached file to /tmp
        by telnet
        opkg install -force-overwrite /tmp/enigma2-plugin-extensions-tspanel_4.1_mipsel.ipk
        or by update button from previous version(yellow-yellow) or directly from all TSpanel servers
        download from first page
        • shiplu
          • Aug 2011
          • 17
          #109
          Hi mfaraj57
          I have another idea, no pressure only if you like the idea.
          How about a panic button in system tools, that deletes cccam.cfg file or c-line/n-line incase you want to delete cccam server evidence in an emergency. or maybe its something that can be expanded in the emu manager section.
          • igius12
            • Nov 2010
            #110
            hello mfaraj, can i find imdb plugin in this version of tunisiasat panel, because in other versions it can't be found, thanks
            • 00360362878
              • Mar 2010
              • 488
              #111
              sim 201 backup
              Hi mfaraj57. I have updated to the latest 4.1version, i then performed image backup and it seems the gjstroom open pli ssl82 isnt happy with the ssl84a that is downloaded. It now only boots to flash mode, so i think it is looking for ssl82, which i assume haw been overwriten with ssl84a. So the question is, can i simply flash the ssl82 nfi or is it a complete reflash? I am happy with the image, so would like to keep it if possible.
              Cheers
              • mfaraj57
                • 557
                #112
                Hi mfaraj57
                Thanks for you
                if i put something in main menu of system tools should be common to all users
                but good idea to add in emu manager
                • mfaraj57
                  • 557
                  #113
                  Cheers
                  Yes TSflashbackup integerates ssl84a with the backuped image
                  however you can flash the image then followed by ssl82
                  i think gjstroom released one compatible with ssl84a
                  TSflashbackup ,gp3flashbackup and dflash are not good to backup of openpli,may be your problem not releated to ssl84a
                  • 00360362878
                    • Mar 2010
                    • 488
                    #114
                    Thanks mfaraj57
                    I assume the image is still in flash, can i just flash with the ssl82 nfi file, just so that i don't lose my settings etc.
                    • mfaraj57
                      • 557
                      #115
                      Thanks mfaraj57
                      Yes if the problem from ssl but as i have said i backup for openpli is not trustful
                      • igius12
                        • Nov 2010
                        #116
                        No answer for that?
                        • southpaw
                          • 2233
                          #117
                          Some problems with settings here mfaraj
                          Tsp / system tools / settings loader / sgtflipflop multi, not working, just reboots dreambox and settings not updated
                          Also cayseyes 11.11.2011 cannot download settings.
                          Also Tried addons / tunisiasat Dm addons / settings / catseye an flipflop both - server down
                          Thanks in advance mfaraj
                          • mfaraj57
                            • 557
                            #118
                            Thanks southpaw
                            i will check that
                            • marcus1975
                              • Jul 2011
                              • 248
                              #119
                              hi mfaraj57
                              In the future will we be able to update the next cayseyes channel bouquet in this way ?
                              [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
                              • mfaraj57
                                • 557
                                #120
                                Originally posted by marcus1975
                                hi mfaraj57
                                yes ,you can but but because files needed to be converted to tbz or ipk so may be some delay in putting in TSpanel
                                hope auther cooperate and put the files in tbz2 or ipk format
