New secondstage bootloader ssl84 for dm800se from sim2
  • mfaraj57
    • 557
    sim2 announced release of sim2-ssl-84-dm800se today according to the plan of continuous support for sim2 dreambox users.
    This great development is one of steps to achieve ability of users to enjoy latest images with latest original drivers.
    sim2 also announced that work in progress to release ssl-84 for other sim2 dreambox models.
    new ssl-84 is used as following
    To use new ssl with original images:
    -Flash new ssl-84 nfi to dreambox by internet explorer or dreamup(this used once if the current dreambox bootloader is ssl82 or older).reboot the dreambox to setup mode again
    -Flash original image as usual
    -Flash ssl-84 nfi to dreambox again and before rebooting the dreambox
    This method may not apply to few images like latest releases of edg nemesis and oozoon and better to use already patched images with new ssl built in
    To use sim2 patched images with new ssl 84
    if the dreambox has old ssl 82 bootloader,flash new ssl-84 nfi first by internet explorer or dreamup,reboot the dreambox again to setup mode, then flash sim2 image
    if new ssl84 already flashed to dreambox just flash the sim2 image by usual method
    with the new ssl ,original drivers and most recent releases of plugins are working without modifications with exception of few plugins like webinterface and software manager may need to apply available specific patches.
    -for better benefit from new ssl better to use with original drivers 2-9-2011
    To take backup for the flash image with integrated new ssl we advice to use TSFlashBackup v 2.0
    To install and to make backup of barry allen multiboot image we advice to use sim2-barryallen v 2.0
  • southpaw
    • 2233
    Nice work mfaraj . Will hold off using until more user feedback . Nevertheless a significant breakthrough from sim2 team again, well done to you an your people
    • Marinero
      • Mar 2010
      mfaraj...that method ?can be used for clone DMse?
      if the dreambox has old ssl 82 bootloader,flash new ssl-84 nfi first by internet explorer or dreamup then flash sim2 image
      • southpaw
        • 2233
        For SIM2.10 dm800SE with 82 bootloader
        1. flash sim2SE_SSL84_0923-nfi.rar
        2. flash sim2.01 bl84 cracked image
        • mfaraj57
          • 557
          this step may be necessory if dreambox loaded with ssl76 but not must for dm with ssl82
          • southpaw
            • 2233
            Thanks mfaraj, just to clarify, we dont need to flash 84 SSL over 82, only flash 84 if you have old 76 in flash .
            82 flash can upgrade to 84 with normal 84 image flash only?
            • Decoder
              • 46
              So is this true please i.e. OK to flash 84 if your 800HD se has 82? Many thanks
              • bozzi
                • Nov 2010
                • 6
                Dear mfarai57 can this be done with dm800 hd original also an also what is the advantage of upgrading to sim2.1 please answer..thanks
                • southpaw
                  • 2233
                  If you got a genuine box mate then a sim2 would not be an upgrade. Just flash a genuine later image an you will have what all these clones are trying to achieve
                  • reopru
                    • Oct 2011
                    SSL-84 problem
                    Hallo ,
                    I tried to flash with ssl-84 bat I get every time :
                    wrong architecture structure message.
                    Any help?
                    • mtv1
                      The Stig PT
                      • 4413
                      what sim you got make shure the image is suitable for your sim look here http://www.digital-kaos.co.uk/forums...-dm800-122157/ and here where you are now http://www.digital-kaos.co.uk/forums...e-sim2-229354/
                      • fahimjan
                        • Aug 2011
                        • 56
                        Whats new in SSL84 ?
                        SSL82 is working fine !
                        • ivantm76
                          • Nov 2011
                          Can I use older BL then I got ? ie 82 instead 84
                          • mfaraj57
                            • 557
                            sim2 dm800se ssl84b
                            sim2 dm800se ssl84b
                            -used only with original drivers 9-11-2011
                            -nfi,bin and ipk files are attached
                            -better to use already prepared images with new ssl
                            all latest images with the new ssl will be available soon
                            sim2 team
                            • bbstyle
                              • Dec 2011
                              Originally posted by mfaraj57
                              sim2 dm800se ssl84b
                              sim2 team
                              If I have DM800HDse BL 82 can I just flash a image that is BL 84b, or do I have to flash this first, then the Image BL 84b
