recently the time on my box and also my epg has gone a hour back and yes i have tried to change it by timezone a but had no luck also tried to change via t panel it changes and then goes back again can anyone help?
time gone crazy
try updateing the ts panel
what image you using ?
might be a kink in the software
also worth checking the epg updater
seen it somewhere that the feed can be to blame i.e the coax
im using open pli image and ive done the updated ts panel also installed a epg updater still no luck
from here make one for the sats you need
satellites.xml creatorPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
I had nightmares with this for a long time. Have a search through the tspanel repositories and try and find systemtime ro plugin or similar, you can set it to update time from internet instead of transponder which sorts this out. You can also add a new line into /etc/enigma2/settings - config.misc.useTransponderTime=falseComment
