AirPlayer for Dreambox Cracked / Premium Key / Hacked
  • weedman
    • Dec 2011
    • 134
    I found the following link today, I thought I would share.
    Another boring day and another tinkering post. For couple of days I was just resting at home and learning new stuff about computers especially programming. When I was tinkering with my old Dreambox…
    This guy has cracked AirPlayer so you can generate a valid working premium key. So far i've installed the plugin and everything works (I can see the airplay icon), but have not managed to play video this it yet.
    Hope someone else out there may be able to figure it out.
    I've also attached the AirPlayer.zip which includes the cracked ipk to install, a readme, and an exe keygen.
    Read the readme file for instructions, it's very easy to pass the premium key.
    Please report back if anyone manages to get it working (streaming from iOS -> Dreambox).
    - Thanks to those who deserve them, and none to those who don't...
    - DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
    - weedman
  • weedman
    • Dec 2011
    • 134
    forgot to add, to aid in debugging, you can telnet to your box and run the following command:
        init 4; sleep 4; enigma2;
    This will reboot your box and you will see all the debugging output in your telnet console, when you do something airplayer related you'll see it show up.
    example:
    [AirPlayMoviePlayer] loading lib done
    [AirPlayMoviePlayer] seekWatcher started
    Setting Message User
    [AirPlayMoviePlayer] valid premium user
    Other useful locations:
    Plugins: `/usr/lib/enigma2/python/Plugins/Extensions/`
    Global Settings: `/etc/enigma2/settings` (A file)
    Skins Location: `/usr/share/enigma2/`
    Last edited by weedman; 29 May, 2015, 15:56. Reason: added other dir's just for reference
    - weedman
    • xZEDx
      • 69
      hey bud any luck on getting something to play yet...
      if yes have u tried allcast or anything simulator?
      Cheers
      ZED
      • weedman
        • Dec 2011
        • 134
        Nothing yet, I'm hoping to give it another try on the weekend, I'll post more thorough instructions and hopefully we can figure it out.
        - weedman
        • xZEDx
          • 69
          from what i have gathered airplayer doesn't work with OpenPli and OpenATV images
          • Sergeleonard
            • May 2015
            Originally posted by weedman
            I would the following link today, I thought I would share.
            Great job. I Will test this but can you confirm it works with a dm800 hd ? I can't see what architecture it suits in it's name... Thks
            • weedman
              • Dec 2011
              • 134
              I've also come to the conclusion airplayer does not work with OpenPLI due to something with the gstreamer plugin.
              I can't confirm it works on a DM800HD - as I don't have one anymore, but I shouldn't think why not, If your using another image like newnigma or dreamelite, this plugin may work for you and may be worth a try.
              I'm going to try it on some other images when I get a chance, but for now, this is on the back burner. Hopefully other members can try it out on different images and report back if they do get it working!
              - weedman
              • GoldBar
                • Jul 2011
                • 11
                Did you get any further with this?
