pick tv and pick tv +1
  • tony2803
    • 266
    has pick tv,pick tv+1 changed their frequencies as i have lost both channels on dreambox 500s..
  • bubbles69
    • Feb 2010
    • 1150
    No cccam don't decode them you need oscam
    • the man
      • 1660
      looks like more chs will get blocked on cccam soon im told , workin fine for me tho , my guys sound as a pound
      • jfish
        • 799
        from what I have read Sly have trialing out some anti cs on some channels and Pick TV is one, only oscam clears the channel.
        • tony2803
          • 266
          do these files need to be at the server end or at the sub end or both..thanks
          • micflair
            • 275
            Hmm, surely if Oscam can do them then CCcam will be able to do them in the future also?
            • the man
              • 1660
              just there end , nothing needs to be done your end
              if you have a good friend! it will be working like my one.
              the truth we need to not panic its a ftv ch not a sports or movie ch. we dont know whats going on,
              iv never watched it anyway tbh , only tested it my end its fine
              • jfish
                • 799
                as cccam isnt developed at the moment doubt a new release will be out, where as oscam is currently still developed hence the reason oscam can clear channels
                • davvo
                  • Apr 2009
                  • 666
                  whos gonner fix it then you
                  no ones working on a new cccam
                  development has been abandoned
                  • smirnoff_rules
                    • 8603
                    so r u only being clearing though a fta card ie if it goes to a pay channel u wont clear
                    • the man
                      • 1660
                      got it working fine on a old card myself no sub , and my (friends got it working his end so its fine on all chs on my share from him
                      • smirnoff_rules
                        • 8603
                        can u or your m8 test this app out and see if it works cccam cfg to oscam converter
                        • micflair
                          • 275
                          Oh hello smart arse..
                          Maybe I will continiue cccam then.. nah maybe not
                          • davvo
                            • Apr 2009
                            • 666
                            good luck
                            • davvo
                              • Apr 2009
                              • 666
                              thats no good to many bugs
                              convert c line to oscam like below
                              i just worked out how to run
                              oscam as a client no cccam needed
                              the file oscam.provid below
                              put in var/tuxbox/config
                              put in oscam server config (add more caids to server & user configs)
                              [reader]
                              label                         = server ip here
                              enable                        = 1
                              protocol                      = cccam
                              device                        = server ip here,12000
                              account                       = user,pass
                              services                      =
                              inactivitytimeout             = 1
                              caid                          = 0500,0603,1803,0100
                              ident                         =
                              group                         = 1
                              ecmcache                      = 1
                              lb_weight                     = 100
                              cccversion                    = 2.1.2
                              cccmaxhops                    = 10
                              cccwantemu                    = 1
                              put in oscam config
                              [dvbapi]
                              enabled                       = 1
                              au                            = 1
                              boxtype                       = dreambox
                              user                          = user1
                              pmt_mode                      = 0
                              request_mode                  = 0
                              user config
                              [account]
                              user                          = user1
                              pwd                           =
                              disabled                      = 0
                              expdate                       =
                              group                         = 1,2
                              hostname                      =
                              uniq                          = 0
                              sleep                         = 0
                              monlevel                      = 0
                              au                            = 1
                              services                      =
                              betatunnel                    =
                              ident                         =
                              cccmaxhops                    = 10
                              keepalive                     = 1
                              numusers                      = 0
                              penalty                       = 0
