pick tv and pick tv +1
  • the man
    • 1660
    #16
    Originally posted by smirnoff_rules
    can u or your m8 test this app out and see if it works cccam cfg to oscam converter
    seams fine . thanks
    • davvo
      • Apr 2009
      • 666
      #17
      it puts stuff there that you dont need
      also it puts the text in the wrong format
      read of address errors all over the place
      • spaintek
        • Sep 2011
        #18
        having a similar problem on cc cam using premier sports descrambling ecm but black screen canj any 1 help
        • spaintek
          • Sep 2011
          #19
          is this the same with premier sports im getting the same problem, sky sports ok but no pick tv or premier sports opening in c ccam
          • waj_uk
            • 175
            #20
            Yes only on Oscam now apparently, anyone got a idiots guide in how to get them working, and if i already use CCcam for my other channels can i still do that?
            - Sent from my iPhone using Tapatalk
            • SparkyUK
              • 53
              #21
              Ive got the same problem.
              Want to view Premier sports
              • micflair
                • 275
                #22
                Get reading up on oscam boys, the sooner the better as Sky are obviously going to switch em all to this.. Im assuming your viewing from your own cards here, if your not then it will be pointless switching to oscam, it has to be at the server end as such..
                • RuberDuck
                  • 1724
                  #23
                  LMAO then once every one has moved to oscam they'll do as they have down under and disable them from being read in any thing but a offitial receiver.
