dish is not rotating
  • ryand28
    • Apr 2011
    • 6
    well im in trouble, i have one dish with one lnb 2 way, the prob is that when i go with the dreambox in another room the dish will not rotate?
  • tony2803
    • 266
    i take it that you have set up the 2 dreamboxes exactly the same with image/scan and what not..
    • ryand28
      • Apr 2011
      • 6
      nope, i go with the same dreambox
      • tony2803
        • 266
        it will not rotate because you have to have both lnb sockets connected to lnb socket on motor,i take it that the cable you are using upstairs is plugged into lnb directly and not going to lnb socket on motor.
        • touchstek
          • Mar 2010
          • 26
          Tony is very correct. that's the reason for your problem
          • ryand28
            • Apr 2011
            • 6
            yes thats right my frend, i have one cable in motor and lnb, and the other one directly to lnb, do ihave to use a normal splitter?
            • Jo-Jo
              • 511
              you could try to split the feed to the motor into 2 but it may not move worth a try tho i supose.
