EDG Nemesis 2.2 on DM500HD
  • markshore
    • Oct 2010
    • 120
    Hi just flashed the image and it looks ok but the bouquet that i am using is greyed out, i can view channels by going into sat providers etc but when i do it shows 2 for each channel one white that works and the other that is greyed out but shows the correct picon any ideas.
    The error is check tuner config and have done this
    config mode=simple
    mode =single
    satellite =astra
    send diseqc=no
    Also this image reset my password back to default as well so was unable to use DCC or dreambox edit until i worked this out!
    'hello, i have just uploaded a sky bouquet from here onto my dm800 hd via dream edit and it loaded up to my dm800 fine, but when i try to view a channel on it like bbc1 it says no service found, please configure tuner or something like that. How can i fixthis? I have a sky dish.'
    seen this post, any ideas
    Regards
    Mark
  • markshore
    • Oct 2010
    • 120
    Update put old image back seems to be working ok re-booted now check tuner appears again.
    On the old setup it showed astra 2a/2b/2c/2d in the tuner config.
    now the only box is astra 28.2 .
    When you do a new flash what does it actually do, are there still settings/ files left on the box as it seems strange.
    Should there be anything in the default services box as although i went in and changed to yes every time i go back in again it defaults to no?
    Regards
    Mark
    • Hadi El Henawi
      • May 2011
      Nemesis v 2.2 Password Problem with DM500
      hello, tried to use dreambox edit to arange channels,( gave a message wrong username and password.)
      I used root as user name dreambox as password but it seems that this doesn't go with nemesis v 2.2.
      Any help will be appreciated.
      • patch
        • 69
        go into tuner config and set lnb for the sat you are on , to lnb 1 then exit back to picture and this returns channels to white ( not greyed out) hope this helps
        • alom5
          • 1648
          get rid of the image, caused me loads of problems......then i got a different image................and everything was fine and dandy again.
